well darkwood is technically,correct, but who on here does everthing by the book?
sorry, do you mean you use materials for jobs that they are not intended for?
I'd stick with your ''screwed'' connectors they will surely out perform a ''crimped'' connection!! Well in your world anyway!! lol!!
Perhaps in China they do as they please with crimps lol just accept the fact you have been wrong all these years, please use the right crimp for the right job, the type of crimp that this threat started with as far as I could make out is the straight through insulated blue type, which is fine as long as it is used on stranded / flexible cores and in an enclosure. End of story
I will answer with a question. If the connector is rated at 24 amps the 2.5 that it is joining is rated at somewhere between 17.5amps and 24amps, excluding Ref Method E (according to BS7671). So unless the cable is in free air the connector is rated within the cable rating.So question... if its 24amp rated for using 2.5 can you use it as part of a ring main thus the front end 32amp mcb effectively overates a connector in the ring main?
If it is in Free Air (Ref Method E) then a better rated connector should be used or have I missed something?
