do I need an earth stake - metre is 25m from fuesboard | Page 2 | on ElectriciansForums
Discuss do I need an earth stake - metre is 25m from fuesboard in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi there, on a new build Im currently doing, they have decided to put the mains supply (metre etc near the front entrance, I have run a 25mm 3core armoured and have put an isolator in the mains cupboard, its about a 25m run from the mains cupboard to the mains cupboard, do I need any additional earthing measures?
thanks
So is the "metre" 25 "meters" from the cupboard or is the "meter" 25 "metres" from the cupboard?? I'm confused dot com.
Told you to stick to feet and inches. No confusion then!
Exactly!!
You should have seen the confusion in the engineering industry during the change over from Imperial to Cillimetres. Drawings arriving on the shop floor printed on Metric sized paper with Metric dimensions which had been converted directly from the original Imperial dimensions and given to a bloke whose machine and measuring instruments were Imperial. The poor sod (me) had to spend half an hour or so with calculator & pencil changing all the dimensions from Metric back to Imperial before the job could be started. ... Madness!!!
The Grantham grocer's daughter fixed it though when she arrived on the scene with her Final Solution ..... :censored:
Ah yes!!!
Dad's Army ... classic comedy but why did I never see a Geordie in it?? :angry:
Earth rod every 5 yards, hammer it straight through the SWA . No need for any of that silly green/yellow cable then
Reply to do I need an earth stake - metre is 25m from fuesboard in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You would treat it as a TT installation.
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
