Darkwood
Not really. It’s underneath a wall cabinet in the kitchen.
But I’ll suggest it to them as an option that will be cheaper than damaging the floor upstairs. 😂
You might want to check if they have spare tiles, etc, as then it could be repaired quite well after any extension of the cables has been done.
You might also move that box down a half-height and the new one up half-height, etc, if that would allow another set of sockets be fitted and a few cm of cable for a proper joint.
This morning’s find when installing a machine from existing board.
took me a moment to process why my eyes were arguing with my brain!
edit.
the blue is actually a N so I presume the same person has connected both ends.
I had one like this a long time ago, not long into new colours, and it took me a minute or two to twig. Like you, I had an instant sense something wasn't quite right.
Mine was finishing off an initial verification after the original sparks fell ill, and it was an unforgettable lesson to not only check the 2 pole lights up like a Christmas tree at the right times but to check which lights are on when!
What should have been a simple job is going to be a lot more involved.
Tiled walls and the CPC of one leg of the ring is broken in the kitchen in such a way that it can’t be fixed easily. Oh and the whole house is on one ring.
Could you make a connection like this using some stranded flexible wire, protect the live conductors while you solder with a powerful iron. Obviously you would use insulated green yellow 1.5mm2 cpc from a flex cable but I could only find brown. I find I can form the wrap on a test piece of 1.5mm2 and then slide off and on to conductor to be extended.
You’d assume (or I did anyway) the singles were the ring and the other crazy things are later additions.
It turns out the 3core 1mm is the outgoing ring and runs half the length of the building!
Also the cut T+E was run in parallel to the next socket and the other end end was still connected.
It seems someone then started a rewire and gave up, the blue coiled single is a draw wire.
I’ve given up trying to work out what dark series of events led to this spaghetti.
Everything out then!
Darkwood,
vjsmarwick,
