T
trev
My old man said follow the van. Why, I have no idea.my old man used to grow lattice for salads. they were always above ground, never buried. :stupid:
Only you can determine the condition of the ground and therefore make best judgement as to whether going deeper is better or more rods will be as effective. If the ground is poor conductivity for three metres and your are only putting rods to a depth of two meters then I doubt the reading will improve vastly, but put an additional Rod in slightly further afield then you may have much better quality ground therefore better earth reading.
The general rule is to get the largest surface area in as good ground as possible.
I fully agree that the Rcd will trip on both 33 to 80 ohms and also 215 ohms but do not understand the arrogant remark ' dogs danglies'. Maybe better to give this a little further thought. Why is 33 to 80 better than 215 ohms ?. Maybe this will give an increased assurance that electrode will not rise above acceptable levels. Do not wish to get in to slagging match over this. Designing and installing these on a regular basis. Earth lattice matt over earth electrode will win hands down every time.
I reserve my slagging matches for E54...:wink5:....I've given this loads of thought,believe me,and nobody,including you, have ever given a satisfactory reason why 80 ohms is better than 200. (I dont accept your suggestion of 'increased assurance that it wont rise over acceptable levels'...it would have to rise over 1400-1500 ohms before it became ineffective,and if it was rising that much something is far wrong which a hundred ohms or so at the starting point isnt going to change.
Originally Posted by Buckfast.... Thanks for your more measured response. I think both yourself and another poster took my original post out of context. I stated that i normally get a reading of between 33 and 80 ohms. That is just a fact i am afraid with the conditions that i generally have to install in. I did not state that this is a reading that anyone else has to emulate, quite obviously lower the better. I also stated that i generally bury at a depth of 1 meter again another poster has taken this stick and run with it without knowing, area terrain or anything else regarding the earth pad installations i am involved with. After using both rods and lattice mats for more than 30 years i still maintain that the surface area contact with substrate is better with lattice mats. (Again all sites are not the same and rightly it can be argued tape could be equally as good in different enviromental conditions).![]()
Yep, stick with leaving that 700 ohm TT system (you mentioned previously) in place mate and Do Nothing, rely on that existing RCD to look after all the problems!!
Then don't make blanket statements, because in cases where your not restricted, a deep driven rod will always out perform a 1m X 1m lattice buried at 1m. (burying beyond 1m will always involve the use of excavating machinery, unless you want to be there all day!!) Also as the ground needs to be fully excavated before you place the lattice mat, the back fill will need to be well and truly compacted (preferably in 30cm layers, with a thumper machine) to gain any meaningful value!! By the way, what is the cost of a Furse 1m X 1m copper lattice these days?? I would expect, several times the cost of a couple of 5/8'' copper-clad rods and coupler!!
Thanks for your reply or should i say rant. The original poster wrote asking for ideas and advice. I think i gave a fair response. I do not think he asked for someone to continually re iterate nonesense, which you are doing. Calm down, move away from the keyboard and get some friends. Believe me i am fully aware of both rod , mat and also tape installations. This forum is for fair and measured advice not as you seem to think an ego trip. As i am not prepared to waste valued time on your futile responses by all means feel free to make any sarcastic comments or jibes. I will not be responding to your posts from here on in.
Words just fail me!!
I agree with your point but I doubt very much that you're dumbstruck mate. The killers have a song called Andy You're A Star. In this case, Andy you're not.Words just fail me!!
lol ok but i have worked on a few tt systems and a longer rod buryied deeper usualy will bring the resistance down, i cant think of any other way that will
