Eicr codes | Page 4 | on ElectriciansForums
Discuss Eicr codes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
just to hijack the thread, apologies to anyone and everyone, had this today on a EICR.. 3 x 3 phase DBs along with 3 x 3 phase henley blocks mounted on a 4ft. x 4ft. ply board. board rotted away due to a leaking drain (since fixed). getting to the point where the equipment will be held up by the cables. all 3 boards have SWA cables (correctly glanded) along with a load of T/E. can't see any danger so giving it a C3 with the caveat that if it deteriorates any more it would escalate to a C2. your thoughts, gents.
Picture??
If everything mounted was secure then there is no code in my opinion but I would maybe put something in the covering letter to say about the degradation of the wood in which the equipment is mounted to.
exactly what i done. even if the board gets worse, the cables will hold the gear up without undue stress. gave it a C3.
it is secure at the moment, but any further deterioration of the ply board would leave the DB supported by the cables, some of which are SWA, correctly glanded and supported .
Reply to Eicr codes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Personally, I would just put them in the observations, the inspection schedule is not exhaustive.
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
