EICR rectifications completed by another electrician, what now?
Actually, it does.
It doesn’t make you a professional painter, but a painter is someone who paints.
No.
BS7671 allows me as the Inspector to determine when an installation should next be inspected.
If I do not consider an Installation is safe for continued use, then I am not obliged to state the installation should continue to be used and inspected in x amount of years.
This is what I mean by your misunderstanding of how the sign off procedure works. You have summed it up perfectly above.
It has been explained many times how it works and I have nothing more to add on it. Happy to help but you seem to be digging your heels in a little for some reason even though you are incorrect.
You start by saying additional certification ‘should’ surfice then go on to say that if they want a satisfactory EICR then you will need to test again.
Come on. Jesus.
If the client wants the report to state Satisfactory rather than Unsatisfactory, then the installation would have to be inspected again.
No the client would need to be educated.
The problem with that, is that some Insurance companies will not accept Unsatisfactory reports even with appropriate certification for remedial work appended to the report.
Some insist the report must state Satisfactory.
Which is why I stated first:
“By rights appropriate certification appended to your report should be sufficient.”
^^^ I am looking at the pair of your comments. IMO my 2 pence worth if an EICR has been carried out, and lets say c1 for x c2 for y has been recorded, and remedial work has been carried out to correct the installation with paper work ie MWC, then in my mind that would go hand in hand with the previous EICR end off.
Would have thought that any remedial work carried out after an unsatisfactory EICR would be covered by either a MWC or EIC so job done?
If covered by an EIC, the EIC will show the date of the next inspection.
Yes, that should by rights be the case.
But what if that work isn’t done for 6 years?
All remedial works are to be done as a matter of urgency. 6 years would not meet that criteria.
Yeah, but the next inspection isn’t for 10 years, got loads of time.
Just as long as it’s done before the next inspection, it’ll be ok.
what a farce ........... nobody can agree ............ but thing is for sure, and based on personal experience......... handing an unsatisfactory EICR and a couple of MWC's to a letting agent doesn't always guarantee they will "accept" that the installation is now "satisfactory"
alex kane,
