Eicr | Page 3 | on ElectriciansForums
Discuss Eicr in the UK Electrical Forum area at ElectriciansForums.net
dlt27
Hi all, I have done a few EICR's before however could do with a bit of advice on what codes you more experienced guys would give these observations;
1 Old 3036 DB made up of wooden base/back. (C3?)
2 Underszed main bond. (C3?)
3 Cooker switch mounted 18" above cooker (C3?)
4 Mutiple cct's in MCB (C3?)
Thanks for any input.
Never before have I seen such a well executed example of the blind leading the blind!
Thanks Damian,
The most accurate post so far.
The sooner there is a fraud case against a so called “competent electrician” for an inaccurate EICR the better.
For one thing a competent electrician would have to be defined. Anyone asking “how do I code this?” isn’t competent to carry out the job.
We all know some use inaccurate EICR’s to browbeat clients in to unnecessary work.
If I’ve upset anyone with the above comment you are by inference incompetent to undertake this sort of work. Therefore no apology will be forthcoming.
got some regs to back those up fella????
314.4 - Where an installation comprises more than one final circuit, each final circuit shall be connected to a separate way in a distribution board. The wiring of each final circuit shall be electrically separate from that of every other final circuit, so as to prevent the indirect energising of a final circuit intended to be isolated.
Building regs state as follows: Cooker control switches, extractor fan switches, etc, should not be mounted so that it is necessary to lean or reach over gas or electric hobs for their operation.
Think about it - a pan fire starts and the switch is behind the pan that is on fire. Common sense I would have thought.
You now need to go to definitions,understand what is defined as a circuit, there you will find your explanation and reasoning is inaccurate
[ElectriciansForums.net] Eicr
Final Circuit - A circuit connected directly to current -using equipment, or to a socket-outlet or socket-outlets or other outlet points for the connection of such equipment.
So I read it as:
A final circuit - A radial circuit supply 5 sockets on a 20A RCBO. If you had three of these final circuits supplied by a single MCB this would be in breach of 314.4.
I cannot see how it can be read any other way.
Reply to Eicr in the UK Electrical Forum area at ElectriciansForums.net
