Halogen Light | on ElectriciansForums
Discuss Halogen Light in the Talk Electrician area at ElectriciansForums.net
H
hightower
Went to help neighbour replace lamp in outside halogen lamp because "the lamp has gone". The screws are all seized up and there's no way to get in without drilling the screw, so said for sake of ÂŁ5 it'll be easier replacing the unit. I was off home again as she said "it comes on sometimes, and then goes off".
It's my fault for taking her "my lamp has gone" at face value. Anyhow, anyone come across a flickering halogen lamp before on an external floodlight. It's switched, doesn't have a PIR. My guess is there wouldn't be a lot to them to fail so I was thinking loose neutral or something? The thing is the connector box is seized too so I'm just thinking it might be easier to replace the fitting, but thought I'd ask on here in case it might be something else.
I've checked the wiring at the switch - all nice and tight (now at least). The cabling is only 2 years old - it's a new build and the switch drop was installed by the builders, ready for a 'registered spark' to fit this light at a later date. Light will be about 2 years old also.
Thanks - not sure if flickering is the right term - it's not a fast flicker or where it dims for a split second.
It might go off for 2 or 3 seconds, come back on for a second, stay off for 10 seconds, come back on for 5 seconds etc.
The contact prongs at the end of the tubes heat up, lose their ductility and burn.
Other than that , a bad wiring contact or element is floating.
If you can't get to it -change it , for the cost.
Thanks ruston, very helpful information. Just don't want to replace the light and then figure out it might be a loose neutral at rose it loops from (I don't know where it loops from to be honest, just an example). For the sake of ÂŁ4.33 or something, it's got to be the next plausible step surely.
99% burnt contacts at the lampholder, but this intrigues me:
Why neutral, specifically?
Sorry, poor wording - I wasn't meaning neutral specifically - just throwing an example out there without writing a wall of text. Obviously that has backfired now because I have to explain myself :rolleyes4:
Is the live at the switch stable, you maybe lucky and the N be in there too, but I would take money on it being burnt out.
Seen dozens.
Seen dozens.
It seems stable, the neutral is at the switch too, but I only had my little voltage tester with me when I went round. When I go next I plan on taking the MFT round.
The neutral at the switch was actually loose in the terminal (it was a Hager switch with a neutral loop terminal) when I looked, and I thought I'd found the culprit, but even after tightening up it didn't improve. I even temporarily removed the switch and used a couple of lever type wagos to join the cables - still no improvement.
It's probably a simple re-tightening needed at the light, or perhaps the lamp changed, but I don't have that option as the only way I'm going to get in to it is through destruction of some sort. I'll try a new light and see how it goes.
It is easy to drill the screw out. The majority of those lights are TAT.
The tubes from the wholesalers are not much better unless you specify.
I will do that, but not sure I'd have something lying around of that size to replace it with afterwards so I'll drill it once it's on my workbench.
Most likely the lamp or fitting. Unless it only comes on and off when someone is going up and down the stairs like I've found previously! Nail through the cable.
Reply to Halogen Light in the Talk Electrician area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
