Hard hats | on ElectriciansForums
Discuss Hard hats in the Electrical Tools and Products area at ElectriciansForums.net
edexlab
Uk
I've had a few different hardhats but have yet to find one that really is comfortable enough to wear all day....
Any recommendations?
Looking at scott 600 and the evolite range at the moment!
[ElectriciansForums.net] Hard hats
I had a diamond V and was very nice.
Problems was with the safety glasses, the helmet pushed the arm in and it dug in a bit
Also the head band I think needs washing, feels like grit has gotten on it
So keep your helmet nice and clean and don't get purple colour one
  • [ElectriciansForums.net] Hard hats
Nah sorry pal, basically I have only ever had the cheap white type which most companies make you wear on site, I expect most of the others here have only worn the same type.
I always remember the first time a company supplied me with a hardhat......
I think the design was based on some kind of torture device,
I actually had blisters and hard lumps appear where the bloody thing dug in!
Agony to wear for more than an hour!
I found out they only cost £1.50 from a wholesalers and always bought my own since then!
Any serious recommendations????.............
Sorry adexlab we kind of took your serious question on a comical tangent, the ones I used to get had a padded comfy wrap over the plastic head straps. I can't name any brand but I never had any issue with them except they can get a bit sweaty in hot weather but it makes sure no one pinches your hat.
Not sure if your allowed to wear bump caps, but some of them look pretty good, I suppose it depends on the site your working on
As per the usual nowadays most sites insist on hardhats
Some of the blokes wear bump caps, in the factory and on less safety conscious jobs
They aren't too bad in the winter but very sweaty in hotter weather,
I actually prefer a hardhat to them in summer,
plus on installs the bump caps aren't really suitable for the job, as there's steel framework and heavy objects being shifted about!
We can end up wearing them for 14+hrs a day which after a bit the caps are minging! whereas a hardhat is easier to keep clean
Found this review on the screwfix website! I think I've found the solution! !!
Hardest Helmet In The World
5 Mar 2013
ByRobbieLad
,*Liverpool
"*After having a 10kg Brick fall on me from 3 meters , i thought
"Sure that has probably broken my helmet!?"
However i was wrong! The helmet sat, unphased by the brick while i suffered a broken neck and my spinal chord is long gone due to the pressure of the fall.
None the less, fantastic piece of kit. 5 out of 5*"
8*of*11*people found this review helpful.
5 Mar 2013
ByRobbieLad
,*Liverpool
he shouls have been wearing one of these instead. unlike a hard hat, it would have absorbed the kinetic energy of the brick and saved him from spinal damage.
Reply to Hard hats in the Electrical Tools and Products area at ElectriciansForums.net
thanks @Julie That is an incredibly detailed answer. I have forgotten a lot of electronics from my college days through lack of use...
Personally it would annoy me having to use adaptors all the time. Can't you buy a proper UK one?
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
Complete guess, but it's probably cheaper to let a separate meter read a CT clamp and send the data to the charger's microcontroller using rs485...
Okay I've changed it. Think I got away with that.
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
96K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
