chris, relax man. i don't think i said anything about your socket idea; i was just offering a solution that hadn't been mentioned yet.
what you describe above does sound a lot more involved than having a go at the socket, but like i said, i thought we were just throwing out options on how to get it sorted. i wasn't trying to trump your suggestion.
but i do think 30 nicker for inhibitor is dear (unless you're getting a gallon). the last bottle i bought cost £7.99.
A plumber with a freezing kit should take no more than an hour to remove the pipes and alter the pipe work..
looking at the pic it doesn't look like you could get a smoke paper between the plug top on the left and copper pipe, therefore no amount of wiggling and jiggling is going to get it out far enough to undo skt screw on that side, the one on the right might jiggle out enough to get to that screw, however if the one on the left is still fixed the skt is not going anywhere. As far as freezing is concerned that is a non starter as there is not enough room to put clamps + would you really want to freeze pipes that close to boiler even if you had the room. as for draining the system 'why' just lock down all rads so water is still in them so all your draining is water in pipework and in that situation why would you need to flush. just refill system add fernox , bleed rads. this all pointless now as op has cut off plug tops and extended skt. which is near enough what I would have done in the first place, Job done.
How many times! its not an electrical issue it's the bloody plank of a heating/plumbing contractors for putting the pipe over it lol. Once the problem with the pipe work has been resolved the plumber can just un plug it, mountain out of a mole hill
Perhaps I should end my involvement on THIS Thread here
easiest option is to send tidyboiler there. after 30 minutes, there'd be no copper to argue about. :43:
"Hello specs",
Here are some answers from a Heating Engineer to your comments about this Heating System:
The `Freezing` suggestion was immediately ruled out by Me - for the same reason that You wrote.
Your idea of `Lock Down the Rads` - turning off the Radiator Valves on both sides to keep the water in the Radiators has TWO `Drawbacks`:
1. Unless the Lockshield Valves are checked for exactly the amount that they are Open - which is NOT just guessing `2 Turns open` for example - when they are reopened to something which is NOT exactly how they were this WILL throw out the Balancing of the entire Heating System !
And contrary to popular belief Balancing a Heating System CORRECTLY is NOT an easy / quick task - it requires a Digital Thermometer with a surface temperature probe or a Good Quality Digital Laser Thermometer - or as in the `Old Days` - clip on Pipe Thermometers - ideally 2 for each Radiator.
Obviously I know that NOT all Heating Systems are correctly Balanced to start with - but any alteration of the Lockshield Valves is bound to make matters worse - unless People are equipped with the correct Thermometers and are prepared to Re-balance the System which can take Hours.
2. Depending on the design / type of Heating System `locking down the Rads` can easily cause severe Air Locks when trying to Refill the Pipework and Boiler.
I did NOT mention the requirement to Flush the Heating System regarding THIS topic - I mentioned it in a reply to shagbite about the Corrosion Inhibitor that I use and I stated that De-scaling - Neutralising and Power Flushing has often been needed on Heating Systems that I have worked on to try and rectify the `Damage` caused previously by the Heating System Installer or subsequent `Engineers` NOT adding Corrosion Inhibitor.
I really wish that I had NOT bothered to post MY `Thoughts` on the Original Post - I did so somewhat light-heartedly as I would NEVER try to suggest to Professional Electricians / Electrical Engineers how to go about ANY Electrical task - it was just how I would try.
BUT it has developed into Electricians TRYING to Tell Me - a Heating Engineer how to go about Disconnecting Pipework from a Boiler.
I also notice that no-one had ANY constructive criticism about what I described that I would TRY in a similar situation.
Obviously You could state:
1. Leave it to an Electrician.
2. After `Isolating` the Electrics at the Main Switch on the Consumer Unit - can I be certain that there is NO Power to these Socket outlets ? - I would still check the Heating Controls / Boiler wiring for Voltage.
3. Do it the way Guitarist did - He is a Professional.
Apart from these fairly obvious comments - where did I `go wrong` with my description of what to TRY - IF there had been room to try what I described - ?
Regards,
Chris
