help needed very quickly,
L
leekemp85
I have very nearly completed a rewire of a two bed-roomed bungalow, as this was a friend of mine I charged £1400 all in, not a bad price as it took two of us a week (I have been paid already). since I have not been there for the last week the plumber has told the lady that he has spoken to his electrician and I have broken every rule in the regs and has threaten to get an inspector in unless I give £500 cash back tomorrow.
Candie is in the middle so unsure if to believe the plumber or me.
the thing i have done wrong are.
not taken fly leads to the back boxes,
the boxes have not got grommets, this is something I always do but I did not have any on the first fix I was going to do it on second fix but my mate connected the sockets up I totally forgot about it (but is that against the regs?).
there are a few cables close to the surface all in the correct zones I have bonded/ undercoated with plaster, when the finished cote is applied they cables will be fully concealed.
and that is the minimum distance for a socket from a tap.
please be honest with your answers as I will print this off tonight and will be going around tomorrow with it tomorrow.
I have offered to correct the problems (for nothing) but have been told by the plumber that his electrician will do it and finish the work and testing for £500. and he doesnt want me in the house again just the money and the key.
please give your views asap, and what could happen if a inspector did come around to see the problems if I cant cant sort them I am currently with elesca.
thanks and sorry for the long post :-)
snip a grommett, and with a appropriately sized flat blade, edge it in around the cable. you may have to scrape back a bit of the plaster etc, where the cable enters the box. Job done. almost as quick have the face plates off and slide over the cables. both ways loads easier than diggingout the box. Same time fit the fly leads to the back boxes. Wish I was there with you. ( not a little person). That was cheap for a rewire !!! The lads have shown you have done nothing illegal. All I would do is prove to your customer you have done nothing illegal, inform trading standards of the scam your customer has been subjected to, and forget it. ( how does he know how much his electrician mate would charge to change things ? )I do see work that leaves a lot to be desired, I personally always refuse to comment on anothers work but if invited to do so will inform the customer of the way according to 7671, I would of done it. I have only ever commented on unsafe situations as it is all our duty to do so.
when I started the job there was 6mm earth taged to the neutral henley block, thats how I left it as pme was going to be installed, I have now connected to a earth rod.
to leave an installation live with no bonding to gas or water and an unknown earth coupled with the other points grommets etc i would have to say, and i am very sorry to, but the plumber seems quite right to question the install, even with his limited knowledge he could see something was wrong and so should lee have :p
tin hat on ;)
The post was nothing to do with right or wrong. it was about the money that he was trying to get from me, I have admitted that mistakes were made. with the bonding how could I connect 10mm when there were no pipes to connect to the plumber came in and ripped everything out the day i was finishing. the main earth tested out OK (0.12) but I knew it was wrong as the pen system was not bonded to the lead incomer that why PME was ordered.
I know this reply us a bit late to your situation, but heres something to help back you up.
If you see the niceic Dvd on periodic inspections, Tony cable actually mentions no use of grommets in his inspection, and says because they are plastered in and have no movement in the box entry, it is not necessary to list as a code recommendation; to fit them. Hope this adds support to your claim.:cool:
regards
Ah i see.
So basically, you did the "first fix" of the main bonding ie ran the cables to the entry points but didnt get the opportunity to carry out the second fix?
And you are saying that the plumber decided to remove all the bonding cable?
Ah i see.
yeah the 10mm was in place, connected at the mains just needed a pipe to bond to, as everything had been ripped out. Job done now.
I would just like to thank everyone for the help I have received over the last few days.:)
Good for you
Now maybe the time to check on his registration and a letter to the inland revenue
Ask whether the claim he was making against woulkd have been covered by your responsibility for deductions to contractors, who try to impose fines for work they are not involved in
Get his name and address to go with it
Any dodgy nonesense by him may come to light
how did you issue your EIC then :confused:
lesson learnt then ;)
not sure i would power up a new install with no main earth or bonding in place especially with other trades on site as if anything was to happen you wouldnt have a leg to stand on :eek:
put it down to experience and move on ;)
Asked him to meet you when he turns up give him a good kick in the nuts make sure you hurt him.
then tell him you want paying for your trouble.
put it down to a lesson of life, your young, people think that your young they will try it on.They still try it on when your old but by then you got good answers to give back.Take the lesson on broad dont take money before you finish the job, If another trade holds you up let them no that you can not do **** all to they finish their work.
Good luck mate don't let it put you off.
Think they gave you a rough time as well because of your age, not that that should make any difference as to how qualified you are to rewire a house as it isn't rocket science after all ( if it were I couldn't do it ;)).
leekemp85,
martinaeo7,
