HELP sizing SWA___________ | Page 4 | on ElectriciansForums
Discuss HELP sizing SWA___________ in the UK Electrical Forum area at ElectriciansForums.net
Judd
Liverpool
For a Job I need to extend and relocate 3x SWA cables, after inspecting the cables I first concluded that they were 25mm 2core, after then comparing an off cut of 25mm 3 core to the existing cables the 3core appears the same size or even possibly smaller, I am now pondering if the existing cables are 35mm 2 core,
I only have the one picture at the moment but will be able to post a picture of inside the enclosures in a couple of days, all cables fit into a standard 60947-3, would 35mm fit into one?
Any help appreciated thanks
[ElectriciansForums.net] HELP sizing SWA___________
As above if you asking about volt drop, how far etc.
Just out of interest, will there be another phase supplied or are you planning on splitting one of the existing?
I can only work with what the Dno supply they'll be reinstating the existing 3 meters and supplying a 4th how they do this is down to them.
Reply to HELP sizing SWA___________ in the UK Electrical Forum area at ElectriciansForums.net
You would treat it as a TT installation.
This is an interesting issue. I agree with you however I took this to task with a scam inspector some years ago and we agreed to disagree that...
