N
nickblake
Nick,
There are two 32A MCBs on the consumer unit so I guess that one of those would be used for the oven. Looks like he was right when he said 2.5mm2 cable was ok! Sadly his workmanship has undermined my faith in his electrical knowledge.
Once again Nick, thanks.
you cant use a 32 amp mcb on a 2.5mm cable ,as ezziekiel has mentioned look at the manufacturer installation instruction if they do say 32 then you will need a 6 mm cable for this , what might be an idea would to contact another electrician to have a look at whats been done
