Help with Wylex board | on ElectriciansForums
Discuss Help with Wylex board in the Electrical Tools and Products area at ElectriciansForums.net
Sheffield
Doing a CU change yesterday, having purchased an 8 way Wylex board and 6 Wylex miniature RCBOs recently, and was about to fix the board until sods law, it's a stud wall and the screw holes don't align with the vertical battens. Decided the easiest thing to do would be get an 11 way. As I was working a bit far from my usual wholesalers I got one from a local CEF, took it back and fixed to wall no problem. As soon as went I went to clip the first RCBO in....... ----, realised it was a half din rail with nothing for the breaker to clip onto at the bottom. Rushed back to CEF and the guy who to be fair was very helpful looked into it and said it was a different model of breaker I needed, but guess what..... they don't have any!! Advised me to try other wholesalers in the area, but none could help and they were all perplexed as the number for the RCBO I apparently need is the old type and the board I bought was brand new!
I was able to fit the breakers for the time being by but they are only secured at the base by being screwed to the busbar and I cannot leave it like that. I'm being searching Wylex's range of products online all morning but I'm still non the wiser. Have Wylex in their infinite wisdom gone back to half DIN rail assemblies, without updating their range of breakers, or am I missing something. Much appreciated if anyone can help me.
I would have used plaster board rawl plugs, the metal screw in ones. Man, you've gone to a lot of trouble for the sake of a rawl plug ?
Or possibly screw a piece of ply on to the wall into the joists, it would only be a little bigger than your original board.
Normally I would but they would have been too close to the hole for the cables
I wouldn't use only plasterboard spirals to fix a CU... but I would use them to secure a piece of board to the wall with some grip fill behind it... essentially the grip fill is bonding the board to the wall and the spirals are just holding it up until it's gone off.
Plywood is a very handy thing to keep in the van... I use it in preference to softwood for making little noggins to screw plasterboard to for hole covering.
I never ever use Wylex. Far too many different breakers for different boards. Why can companies like hager maintain the same design or at least design them to fit previous boards also? Money making scheme from wylex
No difference drilling extra holes in back of enclosure to knocking out 20 mm holes in bottom and putting grommets in
Knocking out holes that the manufacture built into the design is one thing drilling new holes into the manufacturers enclosure is a completely different thing, but don't get me wrong, my original comment was said with my tongue firmly in my cheek,
So what do you do for glands or conduits when knockouts are wrong size/place?
Isn't that the same as cutting a board front cover to fit a different MCB or RCD to the manufacturers recommended, obviously the glands are not to the manufactures original design or they would fit without modification.
Or when you have a board with no knockouts.
Oh, sorry customer, I've just fitted your new board, but I can't cut any holes in it for the cables to enter!
Get real, Mike.
And the holes you have cut have compromised the board the manufacturer tested and fire rated, on the one hand others have suggested that you can not put a Hager MCB or RCBO into a Wylex board even though they fit without modifications, but we can drill holes and fit glands that are not the same as the manufacture used to fire rate and test their board, can we have it both ways? tongue still firmly in my cheek.
Reply to Help with Wylex board in the Electrical Tools and Products area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
P
Large floor tile adhesive help Hi all, My 1st post and just wanting some help/reassurance on a DIY bathroom refurb. I’m putting down...
parrydave
P
It isn't just about premature collapse that is more dealing with the method of support. Ignoring this, cables should be correctly supported to...
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
96K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
