How to shield a live wire at 240V ?
_q12x_
I have a electronic board with leds (made by me) that is driving a relay. When that relay is closing it’s contacts, is actually switching the 240V for the light bulb switch in my room. This board is quite long, like 50cm (half a meter). The relay is in the left corner, and the live wires from it goes in behind the board to the hole in the wall for the mains switch. I also have a mild steel sheet behind my board that is grounded. It is shielding the interference of the 50Hz from the live wires from the wall to my sensitive circuit. But even If I have this grounded metal shield behind my board, the live wires from the relay are still affecting my entire circuit board, keeping it ON all the time. If I am disconecting the live wires from the relay, the board is functioning very well. Another IF, is if I disconnect the ground from the metal shield, the circuit board goes nuts. So the shield is doing it's job fine, but only for the live wires inside the wall !!! But not for the wires from the relay to the live switch.
- I want a way to shield these wires !
Thank you !
q12x I had a go at putting together the circuits I posted this morning and then trying them out on version 1 of my IR proximity switch which is similar to your wings. I only made up two inputs to monitor the state of two of the yellow LEDs ( the 5th and 6th ones counting from the bottom). The differentiator detects the rising or falling edge of the switching pulse, and as wired on the breadboard at the moment it will detect and produce a beep only when an LED turns off. If you watch and listen carefully you can see how it performs.
The outputs of the comparators in version 1 fade and oscillate when the hand is moved slowly or remains still near the threshold points for LEDs 5 and 6. This affects the pulse waveforms which I highlighted in green and therefore the one which controls the 555 using the trigger input at pin 4 - you can hear the effect on the beep and illumination of LEDs 5 and 6.
In version 2 there is no fading or oscillation because I introduced some positive feedback/regenerative switching (hysteresis) at each of the 8 comparators, used some Schmitt trigger circuitry and employed a sample and hold technique which I described earlier ( S, P and Q). As an aside, the ruler LEDs are driven by the state of Q.
Much more work is required with the ideas I sketched out this morning to produce a click effect as good as in version 2. Alas, it will not be by me because I have achieved a satisfactory click effect in a different way and I don‘t have the motivation.
  • FullSizeRender 5.mp4
    41.6 MB
Vishay, BPV10NF IR Si Photodiode, 20 °, Through Hole 5mm package | RS Components - https://uk.rs-online.com/web/p/photodiodes/6997607/
q12x Good morning. I was looking for technical data on some 940nm ir leds and photodiodes I bought off Amazon only to discover that the photodiodes are in fact photo transistors according to several reviewers of the products so I will not be using them for my next sensor array.
I managed to find some 940nm photodiodes and 890nm LEDs on RS - see link and data sheet. This black photodiode has an integral daylight filter. Might be useful for your sensor too. There is a nice graph ( Figure 6 ) in its data sheet showing the relative sensitivity of the photodiode which shows it falling off rapidly towards the visible part of the spectrum.
I have spent a little while studying the way you actually build your modules and the components you use. I notice that you sometimes use glass body diodes for example in your SCM and in op amp circuit (3). Since your circuitry is exposed these diodes may be picking up and producing photo currents due to daylight or lamp light which interfere with or disturb the operation of the circuit. You might want to cover up these glass diodes and see if it makes any difference.
I have been pondering why LED1 is lit whenever one of the LEDs 2-10 is lit in dot mode. The LM3914 should not do this as you have noticed. For correct operation , the Vref voltage has to be less than or equal to the V+ voltage minus 1.5V.
You have two resistor connected in series between Vref and ground and their midpoint connects to the Vref adjust pin. If I remember correctly, the two resistors are the same value which means that Vref becomes 3Volts. This the voltage impressed across the internal voltage divider which provides voltage references to the 10 internal comparators which switch the LEDs on and off.
My first thought is that for correct operation V+ (pin 3) with respect to the V- (pin2) must be equal to or greater than whatever the Vref (pin7 ) to V-(pin 2) voltage is plus 1.5V. Is it?
If Vref V1 is 3V, then V+ to pin2 must be 4.5V or more. Is V+ decreasing below 4.5V when the LEDs turn on?
Take voltage measurement at the pins of the ic.
The way you have wired pins 2 and 4 of the LM3914 may also be causing a changing voltage drop between these pins and also with reference to the local 0V pad. I hope the attached diagram explains well enough that the circuit requires a local start point (X).
see:
https://www.ti.com/lit/ds/symlink/lm3914.pdf?ts=1614700327590&ref_url=https%3A%2F%2Fwww.ti.com%2Fproduct%2FLM3914
Page 18 Application Hints: Three of the most commonly needed precautions for using the LM3914 are shown in the first typical application drawing showing a 0V–5V bar graph meter. The most difficult problem occurs when large LED currents are being drawn, especially in bar graph mode. These currents flowing out of the ground pin (V- pin 2)cause voltage drops in external wiring, and thus errors and oscillations. Bringing the return wires from signal sources, reference ground and bottom of the resistor string (as illustrated) to a single point very near pin 2 is the best solution.
q12x Good morning. I thought of this idea to generate a click pulse whenever an LED turned on. (You would need a second op amp comparator to provide a pulse whenever an LED turned off, wired like the one I have shown but with its inputs (+ and -) reversed). The LM3914 would have to be in bar mode. The idea relies on the LM3914 LED outputs being constant current drive signals to each LED. Each time an LED turns on there is then a step up in current I through the common resistor which connects them all to Vled. Thus there will be produced across this resistor a step in voltage which the CR differentiator across it will turn into a short downward pulse V. During the downward pulse the differential voltage into the comparator will be less than 0V so the output will be 0V as shown by the waveform X. The X waveform can gate the click on and off.
q12x I wondered if you were still looking at this thread? I have just treated myself to an 'entry-level' ie cheap, simple to use yet useful - 2 channel digital oscilloscope as an early birthday present to myself (60 this year in June). I need it to pursue version 3 of my version of your project which tackles daylight and ambient IR.
This is the one I bought yesterday and arrived today:
  • Yah, Hanmatek DOS1102 Oscilloscope is a very nice scope, and very nice presented. Thank you so much for it, mister @marconi . I will consider it for the future
  • This is a little toy I made. Well, it is an addon, an upgrade. It saves space!!! and it fill it's purpose VERY nicely, into my project as a Testing component.
Well, 2 toys. Haha.
- The new updates are awesome and great. With a full support and full help from my good american friend, mister Steve, we manage to make a very practical and very well constructed, very robust in other words, IR remote control and it's receiver. We actually tested it on the wings and is just perfect. I must admit, I like more the remote receiver output to S.5, its very linear and nice to watch. It's a very nice feeling. I will do a video soon about it.
I will start today to build the modules for this remote. Ive also made a range test from outside my room, so it's around 6meters until my testing table and it is working excellent. I can not be more happy about it. I am VERY happy about it.
- Another update is that I receive 10pcs of PIC12F508. I started already to swim in the jungle of tutorials and how to program them. I already have experience with programming PIC's from 1997 to 2003 or something. It's a long story. So its not my first time now, but it passed a lot of time from my tests back then. So I have to remember and remake those steps again. I have an awesome Pickit2 that is still working from those times and the tests so far are optimistic. We'll see. I dont want to talk too much about this subject since it can grow very ugly very quickly in 1000 branches of subjects that is not fun to keep track. Suffice is to say, that I started with it and I have to dig into it more until I can figure it to function optimal.
- The sound problem, the ticks. Mister @marconi , you did very good job and I referenced your work when I thought about this subject. Your doing, for me is an idea and a way to do it. So you helped my final decision even if is not the same as yours. I think I am more happy to build the sound ticks over another lm3914 in paralel with the existing one for the wing leds. I will basically have to drag 3 wires for its module: the signal to pin 5, from the other IC pin 5 as well, and the power pos and neg wires. Thats it. Very compact and robust.
  • The NEXT thing to think about it is the movement of the floating parts I mentioned some time ago. My thought is to use those micro-motors from vibrators in phones, I have 10 of them already and I hacked one to transform it back to motor from vibrator. Another idea is to use "smart wires", basically they are wires that change their shape when current passes through them, and come back to original state when not powered. The catch is they are very expensive. These are ideas for the moment. We will have to think more about this subject. And it is the final thing to add to the project.
  • These 3 remained - the remote, the bip sound and the movement. I am amazed of how it is turning out. And I am very confident it will look and work great in the end.
q12x I too am very pleased to read about your many accomplishments with this challenging project. I will look at the video as soon as you post it. I think you and your work demonstrate what Voltaire said:
No problem can withstand the assault of sustained thinking - philosiblog - https://philosiblog.com/2011/12/02/no-problem-can-withstand-the-assault-of-sustained-thinking/
I think the idea of using a second LM3914 is true genius - so simple, so reliable, so effective, so economical. (I wish I had thought of it!)
I cannot remember the floating parts feature. It will be interesting to follow the evolution of this design so I hope you continue to post. I am not at all familiar with the PIC12F508. I will look it up today.
I have made a an exact replica of my 850nm IR sensor array but using 940nm photodioes and 890nm LEDs. I have connected it to my version 2 and it does indeed appear less troubled by daylight and artificial lighting but not completely. I have not pulsed the 890/940nm sensor yet which is the major theme for Version 3. I thought I would study the signal from this sensor first using my oscilloscope for continuous and then pulsed IR. I want to 'see' the nature and magnitude of the interfering IR signals and the effect pulsing has.
I have not made up my mind yet about whether to have 8 comparators again examining the sensor signal acting as a flash (ie fast and the full voltage range at the same time continuously) analogue to digital voltmeter/converter or whether to only have one comparator and feed it with a ramped/stepped voltage reference and to then sample the comparator output at time/voltage intervals. The former would use something I know works; the latter would occupy less space but would require time and effort to design and test and be a distraction from the real challenge of tackling the interfering ambient IR problem.
Finally for now, I thought I would bring to your attention I discovered the sister ic to the LM3914 while reading up on the operation of the LM3914. The LM3914 is a linear a to d chip. There is a LM3915 which is logarithmic, that is to say an LED lights for every doubling (3dB change) in input voltage to pin 5. A log chip rather than a linear chip would help to even out the points when the LEDs light as the hand approaches - I achieved this by my 10 adjustable voltage references from the blue multi-turn trimmer pots and 10 comparators. The 3915 does the same internally.
https://www.electroschematics.com/lm3915-datasheet/
PS: Look up Bob Pease and Bob Widlar - I think you may be related to them!
The pickit2 reminds me of my introduction to microprocessors during my degree when we used a Motorola 8085 kit similar to this:
https://www.indiamart.com/proddetai...raining-kits-with-led-display-4341655888.html
We had to start off doing really basic things like input a word of 8 bit data, doing some mathematical or logical operation on it and then output it to turn on the appropriate Lights representing the output 8 bit word and then after so many seconds flashing on and off these lights.
About a hundred short exercises which gradually became more complicated. Happy days. I ended up using the 8085 to control a chip which compared in a special way ( cross correlation) two 16 bit words. It did not work until the nth version! I will keep n secret.
I commend this bite-size approach to exploring the jungle.
Thank you for watching it.
Why do you mention the light pipes? I am aware of their existence, but i did not know the name of them if i wanted to search them. So the name is new for me.
What should I do with them?
I thought you could put a cover over the board with the modules on. But that would obscure the LEDs. What you could do is use the light pipes to take the light from the LEDs from the wings moduleto holes in the cover so they could be seen. The light pipes have flat or rounded ends. You as an artist could then design and draw the wings on the cover around these light pipe exit holes.
_q12x_,
marconi,
