I finished a job months ago , now the customer says somethings not working. Do I charge ? | on ElectriciansForums
Discuss I finished a job months ago , now the customer says somethings not working. Do I charge ? in the UK Electrical Forum area at ElectriciansForums.net
england
So a few months back I fitted an outside socket , the customer has messaged me saying it doesn’t work and I need to come and fix it etc. do I charge ? As it was all working fine when I left. Thanks
As above, just think about it, if it is some thing out of our control, then charge for it.
If worked before why does it work Now.
You definitely need to find out what the problem is, and determine whether it is your liability or something the customer has done.
Did you supply the socket or did customer buy it?
So after a conversation, it seems as if the connections have come loose. Basically it’s an outside socket that’s spurred from an existing outside socket. The furthest one (which I installed) is working however the one which was existing which I spurred from is not working.
Make it crystal clear that a charge is made should it be NOTHING to do with the actual work you did . And get them to confirm they understand . Dont work for free
But you worked on it....might have to suck this one up ?
So connections you worked on have become loose?
That's not good, that's very not good, personally I would be going back and putting it right free of charge as soon as possible.
I would be very upset knowing that a connection I made had failed and caused a fault. In the part of the industry I work in that kind of thing would very quickly damage my reputation and cause me all worlds of very expensive trouble.
Reply to I finished a job months ago , now the customer says somethings not working. Do I charge ? in the UK Electrical Forum area at ElectriciansForums.net
I'm begining to think like this now, I very rarely work for builders anymore but the couple that I still do work for are the worst payers out of...
    • Agree
It applies to commercial if it shares the same supply as a dwelling.
