I
inie meanie
Like a drill speed controller or light dimmer a phase angle controlled immersion is going to radiate some electrical interference, only worse because of the larger current and long cable between the immersion and fuse box. What sort of suppression is going to be needed to stop interference with say radios and TVs?
I have been reading up about this issue. Initially I thought it wasn't a problem but with further investigation the triac requires some form of suppression. The particular model I have chosen turns out to have a built in snubber in the package ( 10PCV2425 crydom I contacted tech support at Crydom today ) this is why I haven't seen any evidence on interference. This happens to be the same unit that the EMMA uses so it has pedigree. :- ) As an update from my previous notes I have decided to fit a Henley block and an extra 2 way dist board to make the current measurements easier as I was struggeling to fit all my wires through the current coil. This will be a much neater installation.
