Guest viewing is limited
SJD
Mentor
Now and again, I need to join a cable that is buried in a wall, sometimes in a stud wall, sometimes to be plastered over. Sometimes when someone has drilled through it (last one was a kitchen fitter who should have known better), or sometimes to extend a cable e.g. to move an accessory lower on the wall. Generally I'm thinking of 2.5mm2 or 1/1.5mm2 twin & earth. And assuming a new cable can't easily be pulled through.
What jointing method do people prefer?
I've used heatshrink crimp butt connectors plus an outer covering of glue-lined heatshrink. I worry about the crimp not gripping one of the conductors tightly enough and it coming loose.
I've also used heatshrink solder connectors, again with an outer glue-line h/s covering. If the copper is not clean enough, I worry about a dry joint to one of the conductors.
And what if one cable is new solid T&E, while the other cable is stranded imperial cable?
GO ONTO TOOLSTATION. THINK THEY ARE 32a.
Pardon... . . ?
Just for info people.
one of these with heat shrink over.
Surprising how these have now become acceptable, when I first posted about them, there where subject to all sorts of disparaging remarks, one even that the yellow lever should have been stripped green.
[automerge]1590326642[/automerge]
What size cables are you intending to crimp Mike?
The inline crimps I have for 2.5mm are impossible to squash with a hand crimper: 2.5mm² Blue Butt Connectors - https://www.tlc-direct.co.uk/Products/CTBUTTslashB.html the above unit makes short work of it.
In a scenario of cable being drilled into for example, as a last resort the cable can't be replaced, joint can't be left above wall unit etc (Wago), I've used butt connectors & heat shrink, as you've suggested. I bought some of these, but not used them yet;
They'll be some arguing against using crimp connectors on solid cables, but I've seen that disputed on another forum.
PS Lets not have any book shelf jokes :)
Big Clive on YouTube tested these recently and as I recall was not too impressed with the results. The solder does not seem to flow into the connection too well. Think they are ok for low current applications, but that’s about all.
i've experimented with some of those solder connectors. the plastic melts before the solder. IMO..... RUBBISH.
SJD
Mentor
Braccan heal
If other, please explain
Running own small electrical company.
Joining a cable to be buried in a wall
SJD,
telectrix,
