Joining existing cooker cable | Page 2 | on ElectriciansForums
Discuss Joining existing cooker cable in the UK Electrical Forum area at ElectriciansForums.net
Ayr
Hi, neighbour has asked me if I would move his cooker control switch for him. Since new position of it is further away,this would require joining existing cable via JB or, as is preferable, running a new cable. Running a new cable is a fairly big job,so do the regs allow a JB to be used in this case. Cable is twin and earth 6mm. Thanks
They are only rated for MF when used within their Wagobox enclosures, a type tested thing I think.
You're never getting 2 x 6mm twins in one of those boxes though.
This is the problem with manufacturers, there’s not many options for larger size cable above 2.5mm.
I’ve done 3x 2.5mm in one of the Wago boxes and it was a little tight. Good kit just needs a little bit more flexibility.
We need those Line black egg things to be manufactured again.
Really miss the Line eggs. I still have a couple rattling about somewhere.
Will that still be considered MF ipf? like the idea, but just questioning the vaugeries of the rules.
That's the thing, Pete, stupid, vague rules. I'd feel much better with something solid, with good connections and wouldn't have any problems. eg. I still use 20amp JB's for recessed fittings....remove the fitting for access.....why not if you're working on it?
Reply to Joining existing cooker cable in the UK Electrical Forum area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
