Joining existing cooker cable | Page 3 | on ElectriciansForums
Discuss Joining existing cooker cable in the UK Electrical Forum area at ElectriciansForums.net
Ayr
Hi, neighbour has asked me if I would move his cooker control switch for him. Since new position of it is further away,this would require joining existing cable via JB or, as is preferable, running a new cable. Running a new cable is a fairly big job,so do the regs allow a JB to be used in this case. Cable is twin and earth 6mm. Thanks
I agree that the 20 amp junction boxes are accessible. However they have no cable restraint and are meant to be fixed in place.
Install them well and properly and the cables won't move. Plenty just can't do it.....from what I find.
The main reason for MF (besides money issues) is bad installation practice.
I needed to join a cooker circuit today, due to moving a consumer unit. I used a Wago IP68 box, which is rated up to 41A (with appropriate connectors).
[ElectriciansForums.net] Joining existing cooker cable
I put two glands for T&E in one of the flat sides. The box is somewhat overkill for where it was going (bungalow loft) but was fairly quick to fit.
Screwfix sell them, see: https://www.screwfix.com/p/wagobox-ip68-junction-box/7553R
60A Click coffin would have been good for that job
60A Junction Box - https://www.toolstation.com/60a-junction-box/p98775
Best post so far for good advice IHO, think thats the way I,ll go. Appreciate all replies.
Oh yes you can wago box And they even do a wogo box XL now
The Wagobox XL is only rated to 32A and connectors up to 4mm2. I've used these and found them really more suited to lighting circuits, instead of having 2 or 3 smaller boxes. The larger connectors won't fit into the internal slots.
You can fit the push fit red wago connectors into a standard wago box, they are rated to 41 amp it is a bit of a squeeze though. The 6mm cable will go into a standard wago if you remove the black cable grips (which you don't need with a 6mm cable as the side grips hold it in place) However I have used the click boxes in the past which are also good.
Got any photos? Not a product I know but the name rings a bell.
One I found while clearing out the van today.
The two halfs push and twist together, then can be secured with a cable tie round the middle to prevent tool-less opening.
Cables enter through the ends, which are also threaded 20mm holes, then can be secured with cable ties with the struts at the ends.
Great product. Shame they didn't last.
Reply to Joining existing cooker cable in the UK Electrical Forum area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
