Landlord consumer unit | on ElectriciansForums
Discuss Landlord consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Weston
Stoke
I have just had a rental property tested. The electrician says my consumer unit needs replacing as it is not split load.i am only using 5ways of the current consumer unit and all cct,s are rcd protected. Is this correct?
Sounds like the electrician is trying to get more work out of you!
Although any new builds or consumer unit replacements should be split load or ideally individual RCBO's, that doesn't mean to say yours needs replacing. It complied at the time it was installed and all circuits are RCD protected, which in my opinion, only warrants a code C3 (recomendation) and he shouldn't have said it "needs" replacing.
If your electrician has "failed" the installation based on the reason your consumer unit is not split load then you should find yourself another sparkie! A genuine inspector would have just given a recommendation for this issue. Obviously I can't comment on other issues on the report as you have not listed them.
By the sounds of it, you have a consumer unit with an RCD as the main switch this presents a problem/possible danger that a fault on an appliance, for example, will trip the RCD losing power to all circuits these days regulations require a single fault not to affect other parts of the installation, therefore, would warrant a code 3 improvement recommended. Regulations evolve all the time to try to make an installation safer and should a fault or faulty appliance plugged in it is disconnected as quickly and safely as possible it does not mean that just because of your installation was to a previouse addition of the regulations it is unsafe.
Reply to Landlord consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Google says that North Walney is in the Lake District? Have we moved the wall :)
I opened up the CU again and the round junction box above and what I found was the blue and brown wires coming in from the wall just above the 15a...
2 3
