Lighting circuit taken off ring main somewhere | Page 4 | on ElectriciansForums
Discuss Lighting circuit taken off ring main somewhere in the UK Electrical Forum area at ElectriciansForums.net
Ross1
evening guys, ive come across lighting in one room of domestic premises that has been supplied from the ring main at some point. the cable coming from the ring is 1,5mm which goes through the switch then on to the 2 x 12V down lights. This is on an EICR I`m doing. There is no chance at all of accessing under the floor boards as there is very expensive oak flooring down every where. I believe that from memory you can use a switched fused spur for functional switching. I could then put in a 5A fuse and the load side of the cable will be protected. My concern though is the piece of 1,5mm from ring to switch? your thoughts on this would be welcome. I see this as no different to taking a spur off the ring for an extra socket etc, or am I forgetting some thing?
So electricians that taught me this trade,don't know what their talking about!! (1979) some are proberly not with us any more, and proberly before you was born!!. Close this ****in thread!!
Why ?,
don't you understand it ?
We could have had crap electricians in 1979 who didn't understand it then either lol.
Why ?,
Although, wouldn't have had forums then, or computers, or people banging on about Part P, or people banging on about Electrical Trainee, or Aids, or the Olympics in London, or robots. But wine was cheaper :)
It doesn't matter who was born when or who taught who, the point is that if you think that you need to rip out a 1.5mm cable to protect it from some magical fault between fcu and the ring then we've all got bigger problems than I thought oh and don't forget to pick your dummy up :53:
And we had Raleigh Choppers and soda streams and the back end of punk rock lol , what's not to like
Raleigh choppers and grifters and marathons not bloody snickers
Put it this way, if I carried out a job whereby I fed a FCU with 1.5mm from a ring final and some muppet came arond telling the customer it's bad practice and against regulation blah blah blah... That is SLANDER! Plain and simple! If you then proceeded to charge the customer to replace it that is obtaining money by deception, a criminal offence!
Any of you idiots out there that continue to propagate this myth that somehow the 1.5mm cable isn't protected are talking out of your rear end. I would suggest that you start by picking up a bloody regs book!!!
Not wanting to start an argument again...but if you look in the arms, somewhere in the last couple of days some ----- did that too me.
Coded it a C3 on report(t'was 1.0mm feeding a socket method c from a 13a FCU), and got told it was a C2 by the spark 'rectifying' works...
zzzzzzzz
Reply to Lighting circuit taken off ring main somewhere in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the advice.
Ouch. Danger notice to customer in my book.
