Lights in porch soffit | Page 2 | on ElectriciansForums
Discuss Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
you should remember that this is a fourum. not a stage for you to have a pop at other people or make out you know more than anyone else
please explain my "POP" and also explain "know more" than any one else..!!
oh and for you little childish comment of "know it all" you contradict your self in so many ways!!
moisture in the air has no effect on electrical fittings i,ve seen plenty of batton holders under open porches with no problems. so your post was pretty stupid
moisture in the air corroded through a 12" x 9" RSJ on my property. buggered up the electrical fittings as well.
Reply to Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
and sometimes if the drainpipes have been up a while the brackets can be brittle from sun damage and as you say they are nailed on which can be a...
Stone the crows - B&Q might have the answer for 150mmx70mm ducting, which gets you down to 125mm round! Vents in a choice of four colours...
nicebutdim
N
