Lights in porch soffit | Page 4 | on ElectriciansForums
Discuss Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
So can you get out of having to notify work in kitchens and bathrooms by screwing the fittings to the fabric of the building?
tel has this right
light fixed to outside wall attached to building doesnt need notifying if not a new circuit
a socket does as this could be used to supply a cable that crosses the garden
(i)
The installation of equipment attached to the
outside wall of a house (for example security
lighting, air conditioning equipment and radon
fans) is not notifiable provided that there are
no exposed outdoor connections and the
work does not involve the installation of a
new circuit or the extension of a circuit in a
kitchen or special location or associated with
a special installation.
I would say that Tel was right and it is not notifiable, as long as it adheres to above taken from the Part P silliness.
(i)
I re-read this and would agree with Tel. Less money to pay Elecsa then as I've always notified outside lights!
the bit about exposed outdoor connections. one could argue that this would make a socket outlet notifiable, but then if it was IP55 with a flap on, there's then no exposed outdoor connections, so it would be non-notifiable. typical part pee confusion.
Typical Part P confusion - defintely, however I would say that an outdoor socket is always notifiable.
(i)
I stand corrected.
outside sockets are notifiable mate its in the elecys guide to building regs
the installation of a socket outlet on a external wall is notifiable , since the socket outlet is an outdoor connector that could be connected to cables that cross the garden and requires RCD protection
Reply to Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Another tip for metal boxes, the single box version…. Is to fold flat the fixing lugs that you won’t be using… the top and bottom ones
and sometimes if the drainpipes have been up a while the brackets can be brittle from sun damage and as you say they are nailed on which can be a...
