main cut out fuse | on ElectriciansForums
Discuss main cut out fuse in the UK Electrical Forum area at ElectriciansForums.net
L
lawmanxe
How do you pull out the fuse your self, I've phoned for permission to cut seal and got refused by dno and then went to the supplier they said I can as long as I test and leave certificate for them I'm really confused about changing a consumer unit and pulling the fuse. Help would be very greatful.
Well it's a bit late now to say that the seals were already cut. The supplier often doesn't own the fuse, that is usually the distributor.
Meter companys operatives are only allowed to cut seals to enable them to carry out the meter change etc, there not the ones to contact for a consumer unit change.
Like who?
A lot of people don’t know their job either, it doesn’t stop them changing a CU.
It makes me shake my head when i go into the orange shed, wickes and the like and they sell CU's and breakers off the shelf like they are toys. It just shouldn't be allowed, but it is. I had a call from a lovely lady the other day whose next door neighbour had said they'd change her CU for her and she thought, bless her, that she should speak to an electrician before he did it. Apparently changing a CU is no different from wiring a plug.
Reply to main cut out fuse in the UK Electrical Forum area at ElectriciansForums.net
I think it's more towards what the future brings with them and their ability to measure true power. Half remember a video from bigclivedotcom that...
Written in clauses are essential, but should be fairly standard fare to a solicitor. A similar situation exists around where I live with regard to...
