main cut out fuse | Page 3 | on ElectriciansForums
Discuss main cut out fuse in the UK Electrical Forum area at ElectriciansForums.net
L
lawmanxe
How do you pull out the fuse your self, I've phoned for permission to cut seal and got refused by dno and then went to the supplier they said I can as long as I test and leave certificate for them I'm really confused about changing a consumer unit and pulling the fuse. Help would be very greatful.
Right for a start if there's no seal has there been evidence of tampering? The question you should be asking yourself is are you prepared to take the penilties if you pull the fuse and it all blows up in your face. I work in and train the metering industry if there's a fault with the cutout I have seen evidence of what can go wrong in the way of bad burns etc. I would strongly recommend you contact your supplier who can arrange to get this work done for you.
If and I say IF the suppliers/DNO's were to do a 1/2 day course to gain the relevent knowledge, experience and more importantly the "permission" to remove seals then the whole better off we would all be.
Do as Tony says,but when the deteriorated copper conductors touch within the service cable or cutout,and 16000+ amps flow through them the copper vapourises in the back of your eyes, you better get a guide dog.
Not bad, why?
Because.... (and I'm guessing at what Tony was eluding to).....what's the maximum PFC you'd expect off a 230V domestic line? Do the maths in reverse and tell us what the Ze would be in order to get 16,000 amps flowing at 230V.
Or even, to give it some real-world clarity, at 245V
Reply to main cut out fuse in the UK Electrical Forum area at ElectriciansForums.net
I think it's more towards what the future brings with them and their ability to measure true power. Half remember a video from bigclivedotcom that...
Written in clauses are essential, but should be fairly standard fare to a solicitor. A similar situation exists around where I live with regard to...
