Max ZS allowed on NICEIC cert seems wrong? | Page 2 | on ElectriciansForums
Discuss Max ZS allowed on NICEIC cert seems wrong? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
It looks more professional andyb, I give you that.
Im just tight!
Tysoft is not too bad, but I suppose it is quite an outlay, about £ 175 now I think, but it does look more professional and saves a lot of time and easy to save as PDF for emailimg.
And it fills out max Zs for you.
Guys don't any of you use the NICEIC ONLINE? It creates your certs and notifys at the same time. Certs look great and you can opt to email them and/or send a paper copy.
Plenty if you're using the NIC online thing. " notifies at the same time"
My point being if you doing notifiable work and issuing certs you should be registered with a part p scheme anyway so why shove part P? I am just asking if anyone uses the NICEIC system online as I've just moved over from NAPIT. The debate on Part P itself should be discussed in another thread. It's got nothing to do with the subject in this thread. Personally I think Part P is a good thing. It's not that much of an expense and if your work is up to standard it's not a problem passong the assessment. Less fires caused by bad electrical installations speaks for itself.
Reply to Max ZS allowed on NICEIC cert seems wrong? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
