Megger 1kv IR faulty? | on ElectriciansForums
Discuss Megger 1kv IR faulty? in the Electrical Tools and Products area at ElectriciansForums.net
Mpe123
Bristol
Hi, I have a megger 1741+ that won't perform the 1kv IR test.
Everything else on the tester is good but when I press test with 1kv IR settings it triple beeps, that's with the leads not connected to anything (or connected to a circuit).
Is there an easy fix for this or does it need sending back to megger?
Can I check something - on Megger's IR testing is press and hold the test button, and for 1kv there is a delayed start for safety.
Are you pressing and letting go or pressing and holding?
Ahhhh, thank you! Just have to hold test through the warning beeps and it carries out the test... 🤦👍
Good stuff. That's a decent tester you have there.
When doing routine IR tests at 500v and 250v, still press and hold. My boss used to say 'don't be afraid to warm things up!'
Seeing how the IR changes with time can be informative, e.g. if the results improves the longer you hold it can suggest the test is drying out moist or damp cables.
Reply to Megger 1kv IR faulty? in the Electrical Tools and Products area at ElectriciansForums.net
No. Chauvin Arnoux wouldnt play ball. I thought I had sussed with the capacitors but no. We've too busy with work since to really look into it.
Well done. Leads sound a bit high btw mine are 0.07 when warmed up. Rcd uplift - I either calculate Zs, or use the kitcher trick. See
I've discussed this with the OP directly as we are friends, but for anyone searching in the future, the service manual suggests that this...
That is very cool. It would be the end user software that would make that the absolute king.
    • Winner
    • Informative
Mice are one option, as in they might have nibbles both L and N over a segment, but most circuits seemed OK so far and no other evidence of an...
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
95K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
