I work for a company who installs electric heaters.
Usually we remove old storage heaters and replace them with our heaters using the same point with a new switched fcu.
The fuse board is usually just an old Wylex type with just an on off switch and non switched fuses.
The board is powered from the live coming out of the radio teleswitch meter so to make the board live 24 hours we remove this cable and put it into a Henley block which has permanent live feed.
The questions are....
Are we allowed to touch these meters as there are stickers all over them saying property of the electricity board.
Secondly, using the old points coming from the old style board with just an on off switch. Is this ok?
As to the board change, not enough information. But generally speaking there is no imperative for it to be changed. Although it may be recommended to the client it is just not a yes or no answer.
The company you work for should have some sort of procedure in place for getting the fuse removed.
Any work has to be done to bs7671 18th edition.
If you know these regs then you might be needing RCD protection, SPD, if altering or making additions to the circuit it should be up to current standards.
the correct certificate needs issued every time.
Well, this is interesting reading.
Recently, I attended a house where this heater swap had been done. The company that came only changed the heaters. They told the homeowners to have their E7 tariff changed.
This was done, but the meter guys didn't reconnect the E7 board... leaving my customers without any heating. (said they weren't allowed to).
I was actually thinking of doing this myself as a business idea, but you guys are putting me right off!
Have the customer get an isolator installed from their supplier to make the changeover easier, swap the heaters, test the circuits and move the E7 board to 24hr.
Hence a recent thread I made about disposing of the bricks.
My heater choice would be the Rointe Kyros range, but would accept other suggestions.
Reading the Rointe website, it does say that any warranty would be void if the plugs were cut off... so i'd have to change the switches to sockets, and therefore changing the board to RCD protected if required.
I don't know, but i'd expect other manufacturers to say the same regarding plugs??
Hi Luke - I think Minor Works Cert for changing the supply feed point and another for a new FCU, if I've understood correctly. As you are moving the tails, they would have to comply with current regs for sizing, insulation and support.
Clearly they should not be asking you to work live.
I think we’ve scared Luke off with all this.
Maybe Luke is merely someone who fixes the new heaters to the wall and takes the old ones away. Perhaps the electrical work is done by someone else in his team who is qualified to do so. Perhaps the management above have agreements in place with the suppliers who come round afterwards and reseal fuses that the team have removed.
Optimistic tag alert!!!
Maybe Darth Vader is his father
“NOOOooooo!!!”
“NOOOooooo!!!”
Just the boring dick measuring tradesman replies. Someone asks a simple question and because they don’t know every little rule on electrics that means they aren’t a “sparky” so it’s better to just ignore :)
Leicester
Meters and boards Question
Luke105,
