Discuss MK rapidfix, GAME CHANGER in the UK Electrical Forum area at ElectriciansForums.net
like wise, Megger and Fluke have not been able to make their earth leads in green/yellow. WTF cares. we all know what they are.Is it not possible to make green/yellow plastic, they have opted for green which I suppose does indicate earth whilst those cheap nasty inline connectors we have seen on here opt for yellow which doesn't indicate earth. Seems like a good idea.
Quality of MK stuff isnt what it used to be so I'll be givong these a miss, I also pay £1.25+vat for schneider lisse double sockets which imo feel solid,and 3 terminal screws don't take long to tighten, still gotta do your plate screws anyway
That's put me off 'em straight away... I won't be using 'em.The are the norm in France for as long as I can remember...
and why you don't date French women??? i knew a woman once, 1/2/English, 1/2 French. she used to shave 1 armpit.The main reason I won’t use the french sockets is the funny shaped holes
Was it one of yours?and why you don't date French women??? i knew a woman once, 1/2/English, 1/2 French. she used to shave 1 armpit.
Me too. Not specifically to save time (which they will), but because of the third terminal. Can be problematic to daisychain in some rewires as the existing wavin won't allow two x T&E. Now instead of the traditional daisychain radials, this socket gives the option of the "tree type" radial when circumstances require it. In reality "tree type" radials save on cable and lower FLI which is another bonusi'm going to give them a try.
we all gotta save a tree. combat global warming and all that. but . if it's true, why is it colder in August than most Octobers? don't soundlike warming to me.Me too. Not specifically to save time (which they will), but because of the third terminal. Can be problematic to daisychain in some rewires as the existing wavin won't allow two x T&E. Now instead of the traditional daisychain radials, this socket gives the option of the "tree type" radial when circumstances require it. In reality "tree type" radials save on cable and lower FLI which is another bonus
We all want to see the resultsGot one of these sockets today, looks cool, different, but cool. Think I'm going to have to open it to compare the insides to a normal one.
Agreed. 25mm minimum for light switches. Can metal backboxes not also be banned? (ouch!). If 2 +1,s back boxes were available in pvc, I would never look at one again.One of the issues with plates is always shallow back boxes ! Can they not be banned ? !! Given the chance I always fit as deep as possible.
OK in partitions but plastic boxes sunk in a solid wall would stink of cheap to me.Agreed. 25mm minimum for light switches. Can metal backboxes not also be banned? (ouch!). If 2 +1,s back boxes were available in pvc, I would never look at one again.
Depends.... if they are made like cavity wall boxes then yes. If they are stronger etc and designed to do the job then why not ?OK in partitions but plastic boxes sunk in a solid wall would stink of cheap to me.
A good, solid backbox is a must, IMO.
Interesting....we all come across rusting boxes. It might be a bit iffy installing any electrics in walls expected to be 'dampish', though.You can buy plastic boxes designed for burying, I forget who makes them though. Designed for walls that might rust metal back boxes.
I don't use anything else but them except where unavoidable.. The metal backbox is very poorly designed in my view and lends itself to problem.You can buy plastic boxes designed for burying, I forget who makes them though. Designed for walls that might rust metal back boxes.
doesn't any of youlot still use wood back boxes?I don't use anything else but them except where unavoidable.. The metal backbox is very poorly designed in my view and lends itself to problem.
What’s a back box?doesn't any of youlot still use wood back boxes?
You shouldn’t be bloody looking, tel!typical Scotsman. no knickers under the kilt.
Reply to MK rapidfix, GAME CHANGER in the UK Electrical Forum area at ElectriciansForums.net
