Discuss MK rapidfix, GAME CHANGER in the UK Electrical Forum area at ElectriciansForums.net
That's the one, the price is probably the main reason for using metal boxes!
That is the one. But that is not the price I pay. They are generally speaking equivalent in price to metal boxes over here. I assumed (wrongly) that these pvc flush boxes were widely in use in the UK as well.That's the one, the price is probably the main reason for using metal boxes!
For the first 10 years of my electrical career, pvc flush boxes did, nt exist, but when they arrived I found them to be better than metal in every facet.Other than breaking with convention, is there any technical reason why metal boxes are preferable to PVC? Surely if well fixed, they're not going to be any more prone to movement or flexing than metal boxes.
True. But usually only in the case of light switches. Most other accessories (sockets, 20 amp isolators etc) can still be tested from the face screw due to the internal strap which links the faceplate screw "eye" to the earth.PVC box's will not allow Earth testing from the face screw, other than that I can't see any disadvantage.
9) No more earth fly leads required (yippee!!)For the first 10 years of my electrical career, pvc flush boxes did, nt exist, but when they arrived I found them to be better than metal in every facet.
1)Let's start with the faceplate screws. With metal boxes there is always the possibility of "nicking" a cable due to the poor design of the "eye
When used to spur off on a ring in a metal back box... that's 4 x cpc connections... only 3 wago connections available ?? Or is there capacity for the 4th one somewhere ?I've just had a quick look at the one I have here, It has little test points at the top for L and N, the test points are shallow so shrouded probes will have no problems making contact. It also looks like the earth terminal section is a separate unit, perhaps to allow for a clean earth model? The earth strap appears to be made of brass now rather than steel of the current 2 gang sockets, earlier ones used copper or a high copper content alloy. The white part of the socket is fortunately still made of urea formaldehyde and not the soft melty plastic some MK stuff is being made of now. The switches feel ok and plugs insert the same as existing MK sockets. Looks good!
Back box is earthed through the mounting screws.When used to spur off on a ring in a metal back box... that's 4 x cpc connections... only 3 wago connections available ?? Or is there capacity for the 4th one somewhere ?
Correct if one "eye" is fixed. Flylead still required over here thoughBack box is earthed through the mounting screws.
10) another advantage of a pvc backboxWhen used to spur off on a ring in a metal back box... that's 4 x cpc connections... only 3 wago connections available ?? Or is there capacity for the 4th one somewhere ?
I was genuinely surprised to learn that they appear to be used only IN ROI. Normally NI wholesalers keep a selection of what's used in both the UK and ROI, but not in this case. Will get a link for youwhen i google pvc back box, flush, all i can find is patresses or dry line boxes.
someone told me that I was the missing link. felt chuffed till I googled it.I was genuinely surprised to learn that they appear to be used only IN ROI. Normally NI wholesalers keep a selection of what's used in both the UK and ROI, but not in this case. Will get a link for you
They come in 16mm,25mm,35mm.They are also available with brackets attached to the side for fixing to studwork. CEF do them over here.Or you could go online to "electricalwholesaler.ie".I was genuinely surprised to learn that they appear to be used only IN ROI. Normally NI wholesalers keep a selection of what's used in both the UK and ROI, but not in this case. Will get a link for you
Only seen them here in installations from years ago (early 70's maybe), and they weren't great it's a general treat with caution when trying to screw the plate back on. And not aware of any wholesaler that stocks them, CEF certainly don'tI was genuinely surprised to learn that they appear to be used only IN ROI. Normally NI wholesalers keep a selection of what's used in both the UK and ROI, but not in this case. Will get a link for you
The levers are very low profile, I wouldn't expect them to catch anything.I cant help but be concerned that one of those levers could catch anything when pushing the socket back. Some backboxes are tight with cables coming from multiple directions.
I'm probably just being over cautious
CEF in ROI stock them. They told me they can be ordered in UK from other branches. As to their robustness, they are significantly more robust than a drylining box.Only seen them here in installations from years ago (early 70's maybe), and they weren't great it's a general treat with caution when trying to screw the plate back on. And not aware of any wholesaler that stocks them, CEF certainly don't
What's wrong with a dry lining box in a masonry wall????CEF in ROI stock them. They told me they can be ordered in UK from other branches. As to their robustness, they are significantly more robust than a drylining box.
Appleby do a plastic 2+1.Agreed. 25mm minimum for light switches. Can metal backboxes not also be banned? (ouch!). If 2 +1,s back boxes were available in pvc, I would never look at one again.
Is that a standard backbox or a drying box?Appleby do a plastic 2+1.
Apologies, they're dry liners. Never read previous convo properly the first time.Is that a standard backbox or a drying box?
Reply to MK rapidfix, GAME CHANGER in the UK Electrical Forum area at ElectriciansForums.net
