I've just had a quick look at the one I have here, It has little test points at the top for L and N, the test points are shallow so shrouded probes will have no problems making contact. It also looks like the earth terminal section is a separate unit, perhaps to allow for a clean earth model? The earth strap appears to be made of brass now rather than steel of the current 2 gang sockets, earlier ones used copper or a high copper content alloy. The white part of the socket is fortunately still made of urea formaldehyde and not the soft melty plastic some MK stuff is being made of now. The switches feel ok and plugs insert the same as existing MK sockets. Looks good!
