MK rapidfix, GAME CHANGER
When used to spur off on a ring in a metal back box... that's 4 x cpc connections... only 3 wago connections available ?? Or is there capacity for the 4th one somewhere ?
Back box is earthed through the mounting screws.
but if you really want a fly lead, you could terminate the extra cpc on the box terminal.
when i google pvc back box, flush, all i can find is patresses or dry line boxes.
I was genuinely surprised to learn that they appear to be used only IN ROI. Normally NI wholesalers keep a selection of what's used in both the UK and ROI, but not in this case. Will get a link for you
someone told me that I was the missing link. felt chuffed till I googled it.
They come in 16mm,25mm,35mm.They are also available with brackets attached to the side for fixing to studwork. CEF do them over here.Or you could go online to "electricalwholesaler.ie".
The price for a 16mm single flush box is 65 cent
Only seen them here in installations from years ago (early 70's maybe), and they weren't great it's a general treat with caution when trying to screw the plate back on. And not aware of any wholesaler that stocks them, CEF certainly don't
CEF in ROI stock them. They told me they can be ordered in UK from other branches. As to their robustness, they are significantly more robust than a drylining box.
