Guest viewing is limited
... Respected for its worth - and probably never dropped 2m onto a painted concrete floor ...
Life expectancy must depend on part if it treated kindly , or slung in back of van jostling with reels of T&E.
mine is kept in a padded camera case. for fault finding i use a IR/cont. Megger BM summat, cost a tenner faulty. all it was was a broken connection on the inside of the lead socket. passed calibration and if i drop it it's only 4 pints lost.
Megger 1741, 1735, 1731 and a Metrel 3155 eurotest
Do you still have them all Richy?
Don't worry I'm not looking for a freebie like last time, just interested ?
I have a 1731 which I love. The metrel mi3000 lasted quite a few years though and was adequate, it's now kept as a spare.
HI
Just looking at buying a metrel ML3155 XD
would anyone happen to know what the difference between the standard kit and the euro kit is. for the £400 difference
thanks
I have an embarrassingly large collection of devices,some for work,some for fun,but in the latter MFT club,i have a 1720,with the latest version download,which has been very good.
I took the time to learn it's every option,and would keep it,even on a future upgrade,which will probably arrive out of giddyness,more than need ;)
I would always stress the need to know whatever device,100%,rather than chase any dazzling,newer versions.
In the last month,i have used a DC current meter,and an inclined manometer,both of which,are older than me mum :cool:
@happyhippydad Morning. Happy new year. Yes we still have all those test instruments. The Megger is the daily go to and to date the Metrel has been used mainly on EV testing with additional extra bits; but I am going to take it on as my main tester sometime soon.
We have a lot of Megger test equipment (clamps, earth leakage, AVO, iClamps, PAT testers etc) but these last couple of years have felt the MFT's are not made as well as they used to be.
The last 1700 series we ordered arrived with the top and bottom detached! It was all sorted out OK but knocks your confidence in the equipment somewhat.
[automerge]1577962855[/automerge]
HI
thanks
@rlsecurity if you look on the meter UK website there is a chart showing what is and isn't included. Scroll down to the bottom of this page:
Kewtech KT65 for last 3 years. It’s been reliable and we understand each other. I do have Megger envy building, but the KT just won’t die :) .
That KT65 was one of the few I considered before pitching for a lightly used Megger 1730. Looks nice and fool-proof compared to the Mettrel and Fluke Had a Fluke on loan recently. Can't say much about the accuracy, which should the the most important consideration, but find the 1730's "child's toy" controls far easier to set correctly.
Does anyone else test their MFT against a Cal-Card and a known RCD? Mine gets a run through and spreadsheet log roughly every month. Give me a heads up as to potential issues.
That’s what I did when registered with a Scheme. Then every third year, I’d have it calibrated. I replaced the Calcard then, but then someone pointed out the card is just a set of known resistances, which can’t alter.
As did a Zs test as well as RCD test on the same socket. If was doing it now, I would install a dedicated socket on its own RCBO, to save messing around isolating devices.
That’s what I did when registered with a Scheme. Then every third year, I’d have it calibrated..
THAT'S INTERESTING! I hadn't realised that if you monitor the readings and they remain the same it isn't necessary to fork out anything between £50 - £125 every year for a calibration test. Thanks Midwest.
Personally I advocate annual calibration in addition to ongoing accuracy checks. These are nowhere near as thorough or controlled as the calibration process.
It's all academic for me anyway as RECI require annual calibration without exception.
On my last three NICEIC visits they have changed their minds each time
Was every 3 years
Then endless if I had my own proving unit,
now back to every year.
KT65, selector switch went in warranty, that was just dirt , it does get used in some nasty industrial locations, since then its now over 9 years old still going strong, have another KT65 as back up but never been out of the house.
Only other thing is one of the leads broke
Dan
Staff member
Admin
Mod
Staffordshire
Website
https://www.electriciansforums.net
Other
If other, please explain
Not an electrician at all.
Business Name
Ekthetikos
Multifunctional Testers - Which one have you got and how long has it lasted?
Electrical Tools and Products
Dan,
Lister1987,
