G
Guest 004
Went to a job today, twin and earth, and it had been wired 2 plate, which of course meant that all the switches had the neutral taken to them.
WTF, if I had done that in my apprenticeship I would have been kicked off site.
Is this how things are done now, god I hope not.
Ive just finished my apprenticeship. The boss taught me too do it this way as he said it was easier than risking falling off a ladder 6ft up, i did question whether it was bad practice, he said no. I find myself doing the final connections at the switch is better than leaving a junction box up above, where it could then be a pain in the --- for the next bloke coming in?
Risk falling of a ladder what about takeing a Zs reading....Hold on lets just do the calculation Zs= Ze + R1 + R2 like the Niceic say to do.
I've never seen this and never ever been taught to this. Il also never teach anyone to do it.
so am i at nearly 8 quid a perscription
£8.00 .................Free i wales
as for switch fed , untill lighting manufacturers stop putting idiotic connectors in there light fittings then i will switch feed , but only in wall lights etc where there is a risk of multiple cables being damaged by heat or crushed by the fitting , i way prefer and will always do loop in and out at the ceilings and JB where nessesary
agreed :)))
I rarely do any domestic but if I do the odd one then its loop feed at switches and loop neutrals at the the lights in single core PVC sheathed cable!
The firm I started out with used to use double pole light switches i.e looping a l + n at the switches then firing off a sw + n up to the fitting. I was taught that as long as they were double pole switches then it was ok but i haven't seen this method used since I finished working for them.
Sent from my HTC Desire using Tapatalk
86 posts and still nobody has said why it is bad practice??....Come on E54? ,MrEnigma? etc......What is the electrical reason why a N joint shouldnt be in a switch box?
Nothing wrong with neutrals in the switch box, I generally prefer it due to amounts of spots and fancy light fitting that I'm installing. Easier & safer to wire at ground level and no need to jb in inaccessible positions at the light fitting
Neutrals at switches
Australia
Guest 004,
Dan,
