new consumer unit | Page 4 | on ElectriciansForums
Discuss new consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Hi all.
When upgrading a fuse box to a 17th ed. CU is it a legal requirement to get an isolation switch fitted, or can it be done live. Far from ideal I know, but the £90 price tag set by manweb puts a lot of customers off.
Thanks.
Jay The DNO won't prosecute for cutting seals (extracting electricity they will), because if they lost the court case RE: fitting Isolators to every house in the land as a precedent may be set forcing them to, as you pointed out would cost them a fortune, this is a risk they will not take for a prosecution of criminal damage to the seal, as against live working, cutting the seal is a "lesser crime".
Proving it is another matter.
At the same time they may not actually condone it (cutting seals) in case someone gets injured leaving them open to being sued, but most turn a blind eye, some even issue temporary seals to registered contractors.
prosecutions generally only arise when there's evidence of stealing electrickery. how the hell can anyone prove that there were seals on the fuse before you were there?
Hey, Im doing a board change next week in a small block of flats. At the mains intake on ground floor there's 2No 3phase supplies. These obviously correspond to each flat and 1No landlords supply. Its quite interesting, cos two of the seals are missing, so I deduced these two flats have had new CUs fitted etc and therefore it would be a waste of time sticking a flyer or card through their letter box. So you see this seal cutting thing can be quite usefull in more ways than one.:ihih:
right , thats it , enoughs enough.
to the OP - if you need strangers on the internet to spell out to you how to cut the power for a CU change , then clearly you shouldnt be working on your own.
to the gooner - your use of the written language is a pityful garbled mess.
It's pitiful young Mr Biff ;)
(Pointing out your spelling mistakes since 1951) :)
Reply to new consumer unit in the UK Electrical Forum area at ElectriciansForums.net
2 3
Same as above, if the property is old which your posts suggests i would definetley get an EICR first incase to see what conditon the installation...
