New house - does the CU comply to the current regs | Page 5 | on ElectriciansForums
Discuss New house - does the CU comply to the current regs in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
So I was in a new build today - signed off 3 months ago...
No surface trunking, all cables in walls and ceilings ..... the OCPD's for circuits 1 to 3 look wrong to me
Discuss!
[ElectriciansForums.net] New house - does the CU comply to the current regs
Every new build site barring one I've been on have put smokes on the non RCD side of the CU the other builder wanted it stuck on an RCBO. Both so the RCD wouldn't take out the smokes leaving no safety system. Never seen a cooker or water heater like that though not sure why you would do that.
With the smokes on the non RCD side , how have you ensured that the circuit complied with the regs?
Smokes do have batteries too.
Murdoch, I was waiting for that bit of information you were holding back for when we had all jumped in saying "not compliant"!
Now I'm guessing there's no trick to your op.
So, on basis of what you've told us, the installation does not appear to comply with the current regs.
There, I've said it!
Walls aren't generally boarded over here, sand and cement and floated out before being skimmed
that's how they should be. boarding is just another profit maximising excuse for the builder.
In many ways, these circuits could be fully compliant as I previously stated and why the NICEIC has to be brought into every post I do not know they do not write the regs, just waiting for the dreaded Part P to be mentioned.
I can only possible reasons based on never seen the property.The only person that can really say is the designer/installer. Maybe they should have been RCBO's if so someone doesn't know the regs.
Reply to New house - does the CU comply to the current regs in the UK Electrical Forum area at ElectriciansForums.net
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
