N
nickblake
Take your ReG with you and ask him to show you the Reg then show him the Regs horizontal or vertical . in kitchens the less vertical drops the better due to wall cabinets
the site foreman is correct
As always good workmanship is the crux, and for that point, cables should be installed vertical whenever practical, because trades that follow know not to nail, drill directly vertical below or over any electrical point. It may be old school, but I also insist on the same on any of my jobs. ~If I'm in charge then thats what i want, no argument.
You see where do you draw the line, on a big site? ?Ok this room runs vertical, but to save time and hassel this room is wired horizontal. Trades that follow have to guess?
Anyhow the regs are flawed in many circumstances, the get out is good workmanship must be used at all times, which of course leads to arguments, as this thread.
yes this is true but it was on the speccorrect me if i'm wrong, but i thought part p related only to domestic installs. a village hall is not domestic
7th edition?? - wasn't that around the late 19th Century, when bell wire was OK for Ring Mains?Sorry only kidding.
I have nothing to add to the regulation side, apart from I believe the Horizontal is correct - however who is accurate and who isnt is probably a moot point in this (although in my view you are - right that is). Just a few observations:
a) what were you actually contracted to do - if it was to deliver to 17th edition BR and nothing specific was mentioned - would say you are ok, and you can argue this point. This could take a number of forms
b) Telling him that directly - quoting BR - actually flashing it in his face - preferably done when his subordinates are around to infuriate him further. (although it does have a satisfactory feeling)
c) Maybe going above his head to the Commissioner and suggesting his route with chasing and vertical cables would increase the costs significantly and that as you are getting a fixed rate for this (guessing this) - and that they are actually changing the terms of the contract from a) above - to being specific in how they want it down - rather than to the most cost effective method under the 17th ed BR - is a change in contract and you will have to adjust your costs accordingly.
d) Doyou want to do more work for this "Foreman" or not. Would guess if you argue point a) directly with him by doing b) or c) and win (or lose the argument) that he will black list you in some way from any other local community/council building work - whether legitamately or by just badmouthing you to people who count. Also Commisioners dont like hassle - beaurocrats rarely do - spanners in the works and all that.
jobsworths like this like to be told "Yes Sir, No Sir, Vertical cables it is sir". It comes down to whether your principles for being right and using the correct method that is most cost effective outweigh the value of current and future work from this source.
I would love to hear the story of b - if you get to it- But would suggest sometimes being right doesnt always put bread on the table - who ever said being self employed meant not having to take **** from bosses anymore!
Again only my thoughts on potential outcomes of pushing the point. Hope this helps.![]()
'While you may have a case for good workmanship if the installation was a surface one I don't see the point if it is flush'
Do you mean wiring burried in plaster? I don't understand your point, If it were surface you would see it?
Why would you go to ceiling height and back down for a cooker outlet?
Reply to the thread, titled "New Village hall build Kitchen Ring" which is posted in Electrician Talk | All Countries on Electricians Forums.
