No continuity on cooker circuit. | on ElectriciansForums
Discuss No continuity on cooker circuit. in the UK Electrical Forum area at ElectriciansForums.net
Iona222
Trainee
London
Not getting a continuity reading on the cooker circuit. I'm doing I.r. test and its low between l. N. Any ideas what the issue could be.
The cooker sockets is working also.
What exactly do you mean by not getting a continuity reading? how low was the IR Test? cooker sockets is working also?
I have mate. I'm not getting a reading. When I link line and neutral I get 0.10 ohms
So there must be a break in either the live or the earth. Now, along with the line-to-neutral being OK, you say the socket is working so those may be a clue.
I bet Zs is poor. Although obviously dead tests should be sorted first.
Zs for the installion is OK. But everything fine apart from no continuity on the line earth at cooker. Obviously if there's a fault the breaker might to work
Sound mate.
Zs won't be fine on the cooker circuit I bet.
So, what is the next step you will make?
Reply to No continuity on cooker circuit. in the UK Electrical Forum area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
Induced voltage can be a bit of a red herring when using DVM my guess is somethings moist.
TerryBNZ
T
