no earth on lighting r1+r2 what do you put on sheet | Page 4 | on ElectriciansForums
Discuss no earth on lighting r1+r2 what do you put on sheet in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
ok lets get this write .no cpc in back box and pvc fronts just twin no earth a nob head takes it off
changes the front with a metal switch. fault on the switch
he take it off. he path to earth. that's why the cpc are their for savy
I see your point regarding the limitations, in regards to what code it should be dose it not matter about your un erthed back box & lid screws that someone could come in to contact with regardless of if your light switches are class 2.
Yes I would Code 2 an unearthed metal back box unless it had insulating nylon lugs.
I don't mean to be offensive but are you buzzing Mr Lightyear. I am struggling to have a clue what you are commenting on.
Reply to no earth on lighting r1+r2 what do you put on sheet in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Often, but not always: 543.2.9 Except where the circuit protective conductor is formed by a metal covering or enclosure containing all of the...
In my opinion that is incorrect as the cpc could be broken but parallel paths may not suggest this. From previous threads you clearly have issues...
