P
Plonker 3
Hi spin,
Thanks for clarifying!
The fused spur is a switchable wall mounted box which has been mounted above an already existing wall mounted twin gang socket.
The fused spur wiring leaves the switchable spur box and is contained within metal conduit which runs to the ceiling.
3/4 of the way up the conduit the spur wiring exits to the exterior of the property and runs to an outside PIR light.
Also contained in the conduit is the existing wiring of the radial circuit which runs to the 1st floor sockets.
This hasn't been altered, only in as much as it has been disconnected from the double gang socket in order for the metal conduit to be installed (It's new conduit).
What have you done about the conduit you got a electric shhock off? Did you report it too HSE?
If you are that concerned about your mothers electeics in her flat I would recomend getting EICR carried out at your own cost and then present it too the council should any code 1 or 2s be on it for them to repair.
