Now i am pulling my hair out | Page 2 | on ElectriciansForums
Discuss Now i am pulling my hair out in the UK Electrical Forum area at ElectriciansForums.net
buzzlightyear
Nearly Esteemed
star command
Just put a new cu in started testing .so here it goes start doing rfc line 0.33 nn 0.32 cpc 0.55
Ins all good now this a split load
Dis the cpc what i was working on and now showing earths in and are out so theor is no parallall paths has far that i can see the main earth is out but showing earths all water and gas have been disconnected
Any metal stud work in the property? a lot of other trades use the metal stuff rather than timber these days. often find boxes joined to the metal studwork.
Also any chance of damp or moisture in the walls between back boxes if they have the cpc in them?
Came across something similar when I was still at college and just started working. property had a bad damp problem that once sorted out resolved the irregular readings??
This is where Wander Lead is so so useful :)
Gratuitous reposting of Wanda Ventham
Reply to Now i am pulling my hair out in the UK Electrical Forum area at ElectriciansForums.net
That 'stranded 2.5mm' was probably imperial 7/.029 which is about 2.9mm2. Which might account for expected readings being different.
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
