old rewireables.. | Page 2 | on ElectriciansForums
Discuss old rewireables.. in the UK Electrical Forum area at ElectriciansForums.net
Nottingham
Am I right in thinking that I can carry out a eicr on an old rewireable fuseboard? No install so technically I don't need RCD protection on anything...? I'd prefer to change it to a 17th edition board but customer wants to keep costs at an all time low.
Any thoughts welcome.
Chris
Surely a C2 for no rcd on ground floor sockets unless there's a rcd socket outside. Portable equipment and all that eg lawn mower
Most garden equipment is class 2 so the RCD isn't fool proof.
C3 for me too. You can't go round classifying every installation without RCD's as C2's or C1's - that would get our profession a VERY bad name.
no matter it's classII. you get hold of the L, and the RCD will see an imbalance due to the leakage through your body and, hopefully, trip before it's lethal. no need for an earth on the equipment.
as long as the enclosure is in good condition, the circuits meet disconnection times, adequate earthing & bonding is in place and the correct fusewire is being used....then its OK....
if it complied with the edition it was installed on
Not saying you need to change CU as nothing wrong with it if it passes all tests but you do need rcd on ground floor sockets but just need to install a rcd socket somewhere preferably outside to get rid of C2
All buy petrol mower :devilish:
Reply to old rewireables.. in the UK Electrical Forum area at ElectriciansForums.net
Promised a photo…. Remember, this was working…. And they managed to move in without hitting it…
Definitely, although most likely within the accessories. I've often found that once accessories are disconnected the cabling IR is fine. Sometimes...
