Oven and cooker circuits | Page 3 | on ElectriciansForums
Discuss Oven and cooker circuits in the UK Electrical Forum area at ElectriciansForums.net
Sa29hn
Hi i have a double oven which is 5.8kw and induction hob which is 7.4kw there currently isnt a cooker circuit in the house but there is 2 spaces in the CU so am I correct in thinking I can put 2x32A breakers in and run 6mm cable to both .
Hi new on here and back on the tools after years of point at stuff for others (so go easy). I understand diversity, but with an induction hob it is quite easy to put all rings on and be drawing max load (think Sunday dinner of all the family). The same with the oven when heating up. For the sake of another cable (there is a spare way) and future proofing, why would you not run 2 x 6mm cable on 2 x 32A breakers?
Depends on how they are made. I have installed induction hobs that are rated at a total load of over 6kW yet are supplied with 1.5mm flex and a 13A plug top.
Reply to Oven and cooker circuits in the UK Electrical Forum area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
I actually did it with a 4 core 4.0mm swa last week!
