twin / parallel feeds are pretty common on submains larger than 300mm.
struggling to think of anything else to add to be honest lol.
er , carry on.
hoo hoo Can I join in this thread?? I'll invite Eng54 as well... :)
Parallel circuit/supply needs all conductors to be of the same CSA, follow the same route, cables be of the same type and construction. Parallel circuits can consist of several conductors/cables not just two. Such circuits can and do offer many advantages over a single much larger conductor/cable installation....
If designing the OP's circuit from scratch probably 2 X 16mm would be selected, but in some circumstances even 2 x 10mm could replace a single 35mm cable....
so, in a nutcase, sorry, nutshell, as OP already has a single 25mm, the solution is to parallel a second 25mm cable in.
i already said it in post #6.
Parallel Supplies
Guest 004,
Chr!s,
