Peak output | Page 2 | on ElectriciansForums
Discuss Peak output in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Sorry was back at work.
I initially thought about 10m. But probably about 14 to 15m
Dansk was right, the technical man needs to get more technical, you need a minimum of 4mm but most would use 6mm cable for this length.
Looks like you may have more disruption, get them to change it.
Thanks Earthstore & Dansk.
He said all their systems they have used 2.5mm and some they have had SMA out to replace inverters and they hadn't made any comments about the cable.
If I can get technical, then why cant the technical man
Allowable Voltage Drop1 %
Run Length14 m
Current Demand16 A
System Voltage240 V
Voltage Drop10.71 mV/A.m
Recommended Cable Size6 mm[SUP]2[/SUP]
As always you guys are spot on. A quick look through the manual shows up a Min AC cable size of 6mm up to 23m distance
Mounting instructions state "Do not mount the Sunny Boy on flammable construction materials". Does this mean a fire retardant board? Is it like plywood with plasterboard or something?
Also my RCCB is 30ma
[ElectriciansForums.net] Peak output
  • [ElectriciansForums.net] Peak output
You're already more clued up than their 'technical' expert.
They may have used 2.5mm on all of their other jobs - this doesn't make it right. It just means that they have done all of their other jobs incorrectly also.
Masterboard - we use it all the time - Masterboard
Any GOOD builders merchant will stock it or similar, it's not cheap, (ÂŁ120 / sheet) though one sheet of 8 x 4 will do 4 jobs easily. (4 x 2 per inverter..)
It's stronger than pasterboard, tends to be water resistant also, doesn't have the paper finish.
Reply to Peak output in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
Thank you so much for your input! I will speak to octopus and see what they say regarding a new tariff.
