Paul228
I'd go with my original
Post #32
Post #32
Discuss Please help. Sockets on wooden skirting. in the The Welcome Forum area at ElectriciansForums.net
Looks ok to me i think the plug on the left might be a moulded plug ok, you could argue that it may get damaged by a vacuum , but i dont think i would give it any code
They would be wrong, as there is a Regulation expressly dealing with that stating that they must be mounted at sufficient height to prevent damage to the plugs. However, this was not the issue claimed which was that it was a fire hazard as it was mounted to a skirting board so isn't really relevant to the claims made by the survey (which normally preclude comment on the electrical installation!).But there are others who would say it's fine.
Hi, if the socket is on a plastic back box which is mounted on wooden skirting then no issue, if on the other hand the socket directly on wooden skirting then an issue unless you can proof the skirting is to BS!!!!!Hi. I'm a currently selling my home, a Victorian Terrace house from the early 1900's.
The buyers have just had a survey completed which has highlighted a plug socket mounted on wooden skirting as a fire hazard.
We have been living here since 2013 and have had no issues, this was installed before our purchase of the house. I am keen to understand the regs and my options.
It is a double socket mounted on a plastic back box. It is not so close to the floor that the flex from a plug is severely bent.
I would be really grateful for some advice. I believe it's only because this is a '3' on the homebuyers survey. Can someone tell me when the regs came in and if they relate to installations prior.
Thanks all.
In my opinion is a fire risk if is to close to the carpet .Hi. I'm a currently selling my home, a Victorian Terrace house from the early 1900's.
Thanks all.
so what about an extension lead plugged into a wall socket. extension socket end sitting on the carpet for 20 years, no problems.In my opinion is a fire risk if is to close to the carpet .
Reply to Please help. Sockets on wooden skirting. in the The Welcome Forum area at ElectriciansForums.net
