Pretty sure my cps assessor was wrong | Page 2 | on ElectriciansForums
Discuss Pretty sure my cps assessor was wrong in the UK Electrical Forum area at ElectriciansForums.net
A
AndyL
So I had my yearly assessment today with my friendly local engineer. He was fair enough but there was 2 points he pulled me on that have niggled me because I am sure I was right.
Would like some other opinions please.
Firstly a 60 Amp TN-S supply to a domestic property. ... what is the minimum size tails?
Secondly do you guys tick the double insulated box in S.O.I because of the meter tails?
I'll let you know who was in each corner after a few replies so as not to sway your decision ( as if it could)
That would mean 16mm tails CCC would be 76amps reference method B and maybe couldn't be adequately protected by a DNO 80amp fuse , tho load profile maybe acceptable If clipped direct then 87 amps
The bloke does not know what he is talking about. Lots of sparkys will use 25mm no matter what size the supply cut out is, I will not even up grade tails with a 80 amp cut out. ( you lot may have to depending on installation method)
Reply to Pretty sure my cps assessor was wrong in the UK Electrical Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
