on the note of testing beforehand i think people may be getting that aspect wrong
yes - only quote for the CU change, under the premise that there will be no non-comliance issues or fault finding involved.
if the quote is accepted for the CU change, then job number one is to test the circuits before changing the board. get all your r1+r2's, insulation resistances, check your ring circuits etc etc
if all of the results are fine, carry on with changing the CU - if you have any show stopper issues then you can make the client aware of the problem before you start the changeover.
as far as the client is concerned, once you have swopped the board over he wants his electric back on, it was working fine before and it should be working fine now in their eyes.
that is covering your arse, you'd also need to agree to the cost of a full period inspection if he doesnt want you to complete the work if you find any faults.
ie. consumer unit change = £350 estimated quote
if i turn up, do a periodic, find something wrong which needs remedial work and you don't want to pay for it, then the work stops and you owe me = £80 for the my time and the periodic with cert.
if everything checks out ok on the period, change the CU, charge the customer £350 smackeroonies and provide him with his laminated framed certificate of compliance
I would like to point out that this forum is for EVERYONE, electrician or not.
If some asks for some advice, if anyone feels that you are unable to help, for whatever reasons, then do not post.
Part P is, and at the moment always will be flawed, as with many other "schemes".
I would rather someone ask for help, than just guess or assume what they have done is correct.
The OP has overlooked a serious part of an installation, but that does not give ANYONE the right to abuse them, directly or indirectly.
We can post all day about fast track courses etc etc and the downfalls of them, but, what we all have to remember is there are very few apprenticeships available for people to be taught hands on, to back up the theory.
We were all learning once.
our opinion was asked - it was given
is the forum policy to tell people what they want to hear??
because the replies dont sit well with the OP should we withold our opinions? the OP is apparently NOT an electrician DOING electrical work (BADLY) - hopefully he can take something valuable away from this experience and our opinions may be taken on board. i wouldn't class these posts as abuse. (or the ones i remeber reading at least)
