Problem this afternoon | Page 6 | on ElectriciansForums
Discuss Problem this afternoon in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
Got called to a customer today, background is he has been doing some DIY... he had replaced a load of light fittings and plug sockets, he said we extended this one here and burried it in the wall etc... found one twisted together with tape, no connectors etc... anyway..
The problem is, since yesterday, he said the plugs downstairs don't work... hmmm
I plugged the socket tested in, beep beep beep beep beep, Earth and Live Reverse.... so i go to another, and get the same, then go to another, and its already beeping at me without switching the switch on, its a Fluke socket tester, first two are lit up, then switch it on then its just the first one so suggest Live earth reverse.
I then get the MFT out, plug it in at a socket,
Line to Neutral = 5.5v
Line to Earth = 230v
Neutral to Earth = 230v
Hmm, that's not right...
I pulled off all the face plates down stairs that I could that appears to be on that circuit one at a time thinking ill find the problem, but nope, nothing, all seemed in order (a mess but in the right holes). They said they did not extend or chop any circuits on the plugs, only the lights (they work fine).
Oh its a radial by the way.
So then the lounge, I took the faceplate off, left all conductors hanging (terminated in wagos) turned back on, same problem on sockets, but the ones he had changed were all dead, so im thinking must be somewhere else, put it back together.
Looked at the consumer unit, dual split board, a mess, blatant cowboy who fitted it, everything in the wrong places etc, but anyway, RCD protected. So the circuit was holding fine, as was the RCD.
I put a jumper between Line and Earth and then went round the sockets to get an R1+R2, all seemed pretty much in order, went round everything I could find, all seemed to be ok.
Then hooked Line to Neutral, went round the sockets, not a bloody sausage, nothing, not on any socket anywhere, nothing hooked off the circuit.
Then hooked Neutral to Earth and got a reading on everything.
So then I thought, well everything appears to be in the correct places so what the hells going on... I said it Friday night, I want to go home now thanks, and am going back next Tuesday and have left the circuit off.
My next step is to remove all faceplates on the circuit, so perhaps 15 say, then try to connect one at a time and see what happens.
Has anyone got a better suggestion as ill be honest, im stumped on this, I normally find these things quick and move on, but I spent 2.5 hours then this evening and couldn't work it out.
He assures me he has only changed Faceplates, only 4 of them down stairs in the lounge, you could see they were new. He has not touched anything else on the plug circuit.
the dreadnought on the left should give you a clue...
That's a beautiful ship.
There's a picture floating about on tinterweb of one sailing down the Tyne having just been built at the legendary Armstrong's Works and on its way to its sea trials.
I can't remember the name of it but it's a magnificent sight and always reminds me of Tidyboiler steaming down the aisles of Tesco with her shopping trolley.
Not necessarily, ive got a socket tester that regularly reports a missing neutral on perfectly OK sockets, but since I only use for the noise to give an indication of when I've pulled the right fuse i'm not going to replace it any time soon.
The best one I ever encountered was a callout from a music teacher, he had a little studio for piano and guitar lessons.Anyway he rings me and say's i have got a serious problem with my sockets and need them to use my equipment otherwise no lessons etc.
So in i walk with toolbag and test kit, i know it must be serious he said because i plugged my socket tester in and it beeped and 2 green lights came on, upon showing him that all he had done is proved that there was no problem and the bleep and lights indicate everything is ok he went bright red the Pleb, and he was even unhappier when i charged him 50.00 for the call out. And before anyone says i am cruel they should have carried my tools and tester up 2 flights of steep stairs.
Morning Glenn
Morning Glenn
Morning Mike how are you doing. The story was 100% genuine by the way, i cant believe some people
pretty good mate, just about to get ready for the rugger. And I do believe you there are some numpties about for sure.
Good man it will be nice to chill out and forget about work for a while, and would i also be correct in thinking you will be sampling a few local refreshments.
Yes I am going to go on the Stowfords Press today, it is only 2-50 a pint in the stadium, will go out about 12-45 and back around 6pm I suspect, I am just about to have a shower and get my shirt on lol, should be a really good game, the stadium is sold out and they are closing Kingsholm road for the afternoon. Apparently there is going to be a street party and it is practise for the policing because next year our Ground is going to hold 10 televised world cup matches. I expect there will be a lot of police about to shout abuse at haha
it were summat i got off a website someware...
there was no description other than Dreadnoughts at sea...
on their way to Jutland perhaps?
Very likely Jutland.
Very likely built by Armstrong (Geordieland)
Guns by Armstrong (Geordieland)
Engines - geared turbine - by Parsons (Geordieland)
ENJOY!!! >>>>>> https://www.youtube.com/watch?v=WVwoQTWtIH4
Reply to Problem this afternoon in the UK Electrical Forum area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
2 3
